Wrenching your EF
#4226
Re: wrenching your ef
Didnt know the alternator was some what of a pain remove. I thought it would come right out but i removed the brake booster. Reason i removed it is cause i got a b7 swap from my buddy but he didnt tell me the bolt to adjust the alternator was stripped. It screached bad it was loose as fukc.
#4227
got some EDM goodies coming my way...Electric Adjusting Headlights!!! and GLASS!!!! sadly tho they are for usdm style front ends.
but i will be removing the motors and setting them up on my EE8 SiR Front End. HAHAHAHAHA. then ill sell the the glass EDM headlights.
#4228
Keep up the good work and dont forget to post some good pictures once your finished. Im looking forward to seeing the final product
#4230
Its not pic worthy yet everything is just bunched up right there like i said
it looks clean from the top just when you start looking around you notice that the
harness is just chillen there lol ill grab some pics this weekend i wana clean up with
bay a little bit more
#4231
#4233
#4235
Who the fack changed my title?!
started my wire tuck :D already measured, cut, and soldered/heat shrunk the wires on the drivers side. the head lights, the horn, the turn signals, and 2 misc connectors that i think are for ac and something else im missing are all ran through the frame rail. mosquitoes are a BITCH here in tx so i had to stop, plus it was getting dark
#4237
#4242
pulled my headliner yesterday to fix my roof that some one stood on a long time ago and bend all the webbing... got that fixed. then cut a hole for my da map light, got that wired up. then pulled the auto belts out of my car, threw them in the garbage. installing a set of non adjustable manual belts from a hatch since the pillars are different for 90-91 sedans than 88-89. going to finish that up now then install my system
#4245
got my t1 box in the mail, started soldering/heat shrinking the wires i tucked on the inside, put teflon tape on all my fittings on the t1 box, and all my fittings for my catch can, and the fittings on the back of the block.
also landed another transmission job to a guy in wiscansin as well as locally.
#4246
so has anyone relocated there battery to the trunk
im thinking about putting my fuse box by my ecu and i figure it will be
easier to have the battery in the back im running a sub anyway so i have
the wiring going from the bay to the rear what i dont get is how do you
run the bigger gage wiring into the fuse panel on the posotive side ??
#4247
0x5359-0055
Only pic of the relocate I could find for some reason. 0-Guage run from battery to starter then smaller (OEM scrap) running from starter back to fuse box next to my ecu. 200A fuse. No problems for more than a year now.
#4248
Started to remove my AC and ****, tried to take off my front bumper and couldn't:/ Someone help!, Oh, and i moved my battery to my trunk with the reply above mine! Haha
#4250
0x5359-0055
Found the better pic...
Here's a few of the fuse box. These were taken when I had a question about the terminal that is missing a wire in the top pic, figured out it was the alternator. The pic of the starter was before I ran the wire from the fuse box, but just imagine another wire piggybacked on the starter terminal.
