Worn Valve Guides?? - Honda-Tech
Worn Valve Guides??
Old 04-06-2004, 10:50 PM   #1
DC 2's Avatar
Default Worn Valve Guides??
I just picked up a first Gen B16 from HMO and I swaped it into my Crx Si. I thought It was pinging so I retarded the timing all the way and added 93 Octane. I noticed Today it still made the noise with out the throttle so I think It could either be a valve adjustment or worn valve Guides.
It Starts at 2500 and continues, sounds exactly like detanotion. I say valve Guides cause when I had the header off I notice #2 valves had a small indention on the valves at the bottom of the guides and were shiny siler unilke all the others being dark black. I planning to do an adjustment asap
DC 2 is offline   Reply With Quote
Old 04-07-2004, 07:55 PM   #2
DC 2's Avatar
Default Re: Worn Valve Guides?? (EH3B18B)
TTT for night crew
Old 04-07-2004, 09:00 PM   #3
Cory man's Avatar
I highly doubt that the valve guides will cause a detonation sound. I also have a 1g B16 and from what I have seen they have issues with the LMA's(lost motion assemblies). They make a tapping sound that sounds similar to the valves needing adjusting. Sometimes the fuel injectors will also make a similar sound. I plan to upgrade to some GSR(Same as ITR) lma's. HTH
Cory man is offline   Reply With Quote
Old 04-07-2004, 09:29 PM   #4
BANNED
Default Re: Worn Valve Guides?? (Cory man)
Quote:
so true in the same boat about to change mine and add some bonus stuff while it is out
valve guides usually smoke
that is the way I tell if they are bad
krazie1 is offline   Reply With Quote
Old 04-07-2004, 09:31 PM   #5
onePOINTsix's Avatar
Default Re: Worn Valve Guides?? (krazie1)
i think you mean valve guide seals, worn guides themselfs will not cause smoking (oil leaking into the runners). Do a valve adjustment and see if that sloves your problems
onePOINTsix is offline   Reply With Quote
Old 04-07-2004, 10:43 PM   #6
DC 2's Avatar
Default Re: Worn Valve Guides?? (Sideout)
I say valve Guides cause the valves looked suspicious when i eyed them before install
Old 04-08-2004, 02:47 AM   #7
importboi22's Avatar
my valves are bent and they tick =\
importboi22 is offline   Reply With Quote
Old 11-09-2012, 04:39 PM   #8
my honda crx si i just had it rebuilt i think the rings had time to seat. but it still smokes when you crank it up just running sitting still it dont smoke rev it up blue smoke comes out the back check a compression check 120. compression didnt stay up whent down real quick. some tell me its the valve guides some tell me its the rings. it has a lot of blow bye. i dont know mabey i can get some help threw this web site. i put 300 miles on it.
britnscrn is offline   Reply With Quote
Old 11-09-2012, 05:09 PM   #9
zrickety's Avatar
I would say it's LMAs or something else. Personally never saw worn guides on my high mileage B16. If it smokes, probably valve stem seals and piston rings. Knock sensor should be doing it's job unless you got a tune.
zrickety is offline   Reply With Quote
Old 11-10-2012, 12:15 AM   #10
DCRB's Avatar
my z6 head does this untill its warmed up, and i know atleast of my lma's is stupid stiff
DCRB is offline   Reply With Quote
Old 11-10-2012, 05:09 PM   #11
RanCRX's Avatar
From what i heard. Blue smoke indicates bad piston rings
RanCRX is offline   Reply With Quote
Old 11-11-2012, 12:17 AM   #12
DCRB's Avatar
no blue smoke indicates that engine oil is either being burnt or vaporized. it does not mean rings. a compression test and leak down test will show you what's going on.
I just did the stem seals on my buddies 90 turbo laser that was billowing like a train at 300k miles (yes stock block) cylinders 2 and 3 would pour oil out the exhaust ports from how bad the stem seals were. now it maybe burns a drop or two at high rpms but is billow free.
proof, oem on the left, super tech on the right:
back on topic.
o/p blindly retarding your engine and adding higher octane gas wont just solve the issue. re time it to where it should be, and ONLY run premium regardless, since it's a high compression motor.
that being said what ecu are you running?
B16A2 Head Problems Si_chRis All Motor / Naturally Aspirated 2 05-14-2009 10:22 AM
Need help with quote i got for some head work. a1320honda Forced Induction 9 02-01-2009 11:47 AM
Valve Guides (Portflow) and Valves (Supertech)... Driven All Motor / Naturally Aspirated 3 07-15-2005 04:17 PM
Valves make slight ticking noise after adjustment, LMA? Valve Guides? DC 2 Tech / Misc 4 04-09-2004 05:07 AM
Valve Guides Worn? DC 2 Tech / Misc 1 04-07-2004 10:02 AM
Tags
18t, b16, b16a, bad, crx, ebay, guides, honda, install, noise, si, subaru, symptom, valve, vw, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
