White Some At Idle
Old 04-07-2003, 03:48 PM
New User
nighthunt6's Avatar
Default White Smoke At Idle
Im Running A mini me swap and if i sit at a light and idle for a few min's and then tap the gas i blow some white smoke out but its usually only when i idle for a few mins could this be im running rich or blown Ring? and im also running a Tanabe Cat Back Exhaust with a test pipe
[Modified by nighthunt6, 7:01 PM 4/8/2003]
Old 04-08-2003, 10:02 AM
New User
nighthunt6's Avatar
Default Re: White Smoke At Idle (nighthunt6)
ne one?
Old 04-08-2003, 10:23 AM
NINJASPY's Avatar
check the oil cap, look at it, if it has anything other than oil in it..... that could be head gasket(it was for me), the oil had a milky substance in it.
The smoke could just be polution because of the test pipe, as my friends get puffs of white smoke and they have test pipes and no problems with the engine.
Old 04-08-2003, 11:20 AM
broncoman74's Avatar
Location: Northwest Hills of, CT., United States of America
It is most likely condensation steaming off from water trapped in your hot exhaust system. This is normal, Don't panic. Just check the usual stuff, Is it foamy under your oilcap? Does your exhaust smell like antifreeze? Is your coolant low soon after you fill it? Is there oil bubbles floating in your antifreeze? If not then it is just steam!
[Modified by broncoman74, 3:21 PM 4/8/2003]
Old 04-08-2003, 11:22 AM
fastcrxsi90's Avatar
Location: the asshole of america..., upstate new york, USA
Default Re: White Smoke At Idle (broncoman74)
[QUOTE]It is most likely condensation steaming off from water trapped in your hot exhaust system. This is normal, Don't panic. Just check the usual stuff, Is it foamy under your oilcap? Does your exhaust smell like antifreeze? Is your coolant low soon after you fill it? Is there oil bubbles floating in your antifreeze? If not then it is just steam! [QUOTE]
what he said
Old 04-08-2003, 01:06 PM
New User
nighthunt6's Avatar
Default Re: White Smoke At Idle (fastcrxsi90)
Thanx Guys Ill Check It out i was just worried cause some times when i tap the gas it smells like oil a bit so i thought maybe i need valve stem seals or somthing big cause my block has around 205k miles on it
91b18a1ls
08-26-2012 12:46 AM
mondies_8
04-06-2012 06:43 PM
bpfergu
03-05-2012 05:27 PM
Y0N1P8T5R1F5A4T
Honda S2000
27
10-30-2009 10:53 AM
gunterelectric226
12-03-2008 06:49 PM
Quick Reply: White Some At Idle
