IS 88-89 CRX DASH HARNESS THE SAME AS THE 90-91 DASH HARNESS??
Old 01-04-2004, 01:36 PM
benn2k's Avatar
Default IS 88-89 CRX DASH HARNESS THE SAME AS THE 90-91 DASH HARNESS??
just as stated is the 88-89 crx dash harness the as a 90-91 crx si dash harness?? will the 88-89 work with a 90 crx si?? is is it differnt??
Old 01-04-2004, 01:44 PM
crxgator's Avatar
Default Re: IS 88-89 CRX DASH HARNESS THE SAME AS THE 90-91 DASH HARNESS?? (benn2k)
i know the engine harness were different, but i wasnt too sure about the dash, sorry for not having the info...if you need a 90-91 si interior harness let me know, i have one...
Old 01-04-2004, 01:45 PM
Outsane's Avatar
Default Re: IS 88-89 CRX DASH HARNESS THE SAME AS THE 90-91 DASH HARNESS?? (crxgator)
gauge cluster wiring is different..and the rear defroster, dimmer, hazard buttons
Old 01-04-2004, 01:47 PM
crxgator's Avatar
Default Re: IS 88-89 CRX DASH HARNESS THE SAME AS THE 90-91 DASH HARNESS?? (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">gauge cluster wiring is different..and the rear defroster, dimmer, hazard buttons</TD></TR></TABLE>
wow im a moron i completely forgot about that...
Old 01-04-2004, 02:04 PM
filthyCREX's Avatar
yea, it's different.. it'll still plug in to everything. but the gauges wont work.
Old 01-04-2004, 02:30 PM
benn2k's Avatar
so i do need a 90-91 si dash harness then, thanks for the help, does anyone has one?? and the 88-89 dash shell is the same as the 90-91 dash shell?? i know that the cluster cover is different, a.i.m benn2k
Old 01-04-2004, 02:32 PM
crxgator's Avatar
Default Re: (benn2k)
i have the underdash harness...AIM me crxgator or email me crxgat0r@aol.com and we cant talk further...
Old 01-04-2004, 05:44 PM
MidoriEK4's Avatar
Default Re: (crxgator)
i will tell you this much i went to honda and bought a new harness it is different from year to year. trust me each harness came up with a different part number. hope that helps.
DaN
Old 01-28-2004, 02:39 PM
benn2k's Avatar
Default Re: (MidoriEK4)
whats if i use a 88-89 cluster with the 88-89 dash harness on my 90 crx and just tap into the rest of the wires to make the hazards and dimmer work?
Old 01-28-2004, 03:03 PM
Malgerus's Avatar
Sorry to hijack thread, but rather than start a new one: I'm putting in a 90 Civic Si dash into my 88 std, and I was wondering if the new plugs for the guage cluster (90-91 style) directly depin to my 88 plugs?
Old 01-28-2004, 03:05 PM
benn2k's Avatar
not a prb, your looking 4 answers too..
Old 02-18-2011, 11:09 PM
"goose"jay's Avatar
im having a similar issue with my 89 dx. I have an 89 si cluster and 89 main harness but the cluster harness is definately not a 88-89 its 90-91. The plug the goes to the female end to the tails rear turns...etc.....are different sizes and one has about 4-6 more wires.
Old 02-19-2011, 03:10 PM
Canadian_EF's Avatar
Okay guys.
So basically, the EF's had the same front end completely. The dash, physically, is the exact same from 88-89, 90-91.
The problems you come across is if you're going from any harness to an Si. It won't plug into the fuse box, DX to an Si or vice versa.
The differences between 88-89 and 90-91 are as follows...
Dimmer Switch
88-89 has a relay built into the switch
90-91 has an external relay, mounted behind the steering column
So, you'd have to remove the relay and plug the 88-89 switch in. Some splicing required.
Otherwise, same idea for adding the relay. It's easy to figure out.
Hazard Switch
88-89 is built into the steering column
90-91 is built into the cluster hood
There is only 5 wires on the 88-89 switch, 8 or 10 on the 90-91 switch. I've never installed the 90-91 switch, but, you only ever need those 5 wires from the 88-89 harness anyways...
Defog Switch
88-89 is a large rectangle, can also go in the spare switch spots below and to either side of the steering wheel
90-91 is a rounded, smaller switch. Same size as the 90-91 hazard switch.
There's just some splicing, getting the proper pigtail to the proper harness. No messing with relays or anything else really.
Swapping 88-89 to 90-91 clusters...
That's a totally different, and much more lengthy process.
You need those 3 switches, and the matching cluster hood.
There's quite a few write-ups around.
That's the only wiring changes as far as I can tell, and, the 90-91 has a 'brain' that turns off the cigarette lighter when the car is off.
IF you need more help... just ask.
TehTaylor
04-16-2013 02:31 PM
BrayzieEF9
15
05-06-2010 02:31 PM
red_EF9Si
11-20-2008 06:38 PM
red_EF9Si
10-25-2008 06:43 PM
knwldge54
06-28-2005 03:06 AM
Quick Reply: IS 88-89 CRX DASH HARNESS THE SAME AS THE 90-91 DASH HARNESS??
