whistling noise in engine when accelerating
Old 11-03-2002, 03:31 PM
x00gsr's Avatar
Default whistling noise in engine when accelerating
My gf has a 98 civic ex auto trans and ever since i put an intake in her car it makes a whistling noise when accelerating. Everything seems tight, but i just can't figure out why its whistling?
Old 11-03-2002, 03:34 PM
I took way too long
slowman's Avatar
Default Re: whistling noise in engine when accelerating (x00gsr)
it's air turbulence.
Welcome to the world of modifying cars!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edit: https://honda-tech.com/zeroforum?id=1
[Modified by slowmanEF, 7:35 PM 11/3/2002]
Old 11-03-2002, 03:36 PM
Ees  Kes's Avatar
a possible but not realistic reason would be a supercharger
a possible reason would happen to be a bad ground in the stereo system.
Old 11-03-2002, 03:58 PM
lazy bum shaughn's Avatar
Default Re: whistling noise in engine when accelerating (PanFionasTees)
Cold air intakes do that, dont worry bro.
Old 11-03-2002, 04:20 PM
Rob!'s Avatar
Default Re: whistling noise in engine when accelerating (El Breako Dancero)
Turbo that can cause whistling j/p CAI
Old 11-03-2002, 04:29 PM
89 CRX SI's Avatar
Default Re: whistling noise in engine when accelerating (RaceFacer)
bad ground. alternator whine.
i hadf 3 difff intakes on my car not one whjitsled
Old 11-03-2002, 04:30 PM
New User
Shea-bird's Avatar
Default Re: whistling noise in engine when accelerating (89 CRX SI)
does alternator whine mean the alternator is bad because I just replaced mine and I still hear a strong whine when I step on the gas...
Old 11-03-2002, 04:31 PM
89 CRX SI's Avatar
Default Re: whistling noise in engine when accelerating (Shea-bird)
i believe it is more like a poorly grounded amp or other stereo compnent or not big enough wire running ther. or power wires to close to the RCA's / speaker wires
etc
Old 11-03-2002, 04:40 PM
xtrafastcivic's Avatar
it's the intake....
Old 11-03-2002, 05:11 PM
AaronJ's Avatar
Default Re: whistling noise in engine when accelerating (XtraFastCRX)
it's the intake....
Old 11-03-2002, 05:26 PM
cbrman's Avatar
Alternator whine can be caused by a bad bearing in the alternator as well. my mom's 2000 monte carlo had the alt replaced due to alt whine. they told her the bearing was going bad.
Also, i had my high output alt go bad. I stuck my old stock one back in and it has alt wine. That is why i replaced it in the first place.
Installing a cold air intake makes the engine louder. It is very noticable at first, just turn up the stereo
Old 11-03-2002, 06:43 PM
Cam79's Avatar
Default Re: whistling noise in engine when accelerating (cbrman)
what about a tinging sound???????????????????????????
Old 11-03-2002, 10:29 PM
8400 rpm's Avatar
just like they said, cold air intakes tend to do that
Old 11-03-2002, 11:22 PM
low-tech assassin's Avatar
Default Re: whistling noise in engine when accelerating (8400 rpm)
It's not the intake that does it, but it does provide enough air traveling over the butterfly in the throttle body to produce a whistling noise
All of my friends that have intakes said something at one time or another about the whistling from their engine bay, i did a little airflow research of my own and thats what i came up with.. The angle at which the air hits the butterfly is just enough to break into a high pitched whistle. Take off the intak and drive it around the block. The noise should stop; if it doesnt and someone else says soemthing, let them think youve got a supercharger under there or something
Old 11-04-2002, 01:23 AM
kim_2_da_chee's Avatar
it's the intake....
ditto
its the sound of more air resonating through a larger tube...
u'll understand if u take physics.
Old 11-04-2002, 03:59 AM
kranked91dx's Avatar
don't wories, cold air intake does that very often !!
it's like " normal "
Old 11-04-2002, 06:22 AM
incubus's Avatar
Default Re: whistling noise in engine when accelerating (kranked91dx)
hey people will be intimidated by her car when they hear it, they'll think shes got a turbo or a S/C.
i say leave it. J/K
where is the whine coming from? under the hood (would be the intake)
or inside the car (alternator).
Old 11-04-2002, 06:43 AM
Louie B.'s Avatar
I cured my intake / butterfly whistle by re-adjusting my idle. When you put a CAI on it changes the flow enough that your Idle changes and your EACV has to compensate. Re-adjust your Idle and it goes away, at least it did for me.
Old 11-04-2002, 06:48 AM
Charlie Moua's Avatar
Default Re: whistling noise in engine when accelerating (kim_2_da_chee)
it's the intake....
ditto
3rd ditto to that. If it is not consistant i would defitley check out the throttle body gasket.... old gasket will become corroded(sp)
but don't worry bro.
Old 11-04-2002, 06:57 AM
89 CRX SI's Avatar
Default Re: whistling noise in engine when accelerating (Charlie)
well my short ram intake and aem one dont whitsle. htey resonate at 2500 rpm if thats what you mean but that just sounds bad *** not whitsling.
Old 04-13-2003, 02:18 PM
a2kawaii's Avatar
Default Re: whistling noise in engine when accelerating (low-tech assassin)
No doubt. I noticed the same whine on my 90 Civic, took the butterfly out (I love to experiment) Voila! No more noise. Now on to the distributor noise and steam coming out the exhaust pipe. lol
Old 04-13-2003, 02:37 PM
civicmark's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8400 rpm &raquo;</TD></TR><TR><TD CLASS="quote">just like they said, cold air intakes tend to do that </TD></TR></TABLE>
mine used to, but doesnt anymore
Old 01-20-2005, 02:42 AM
Yew_Yun's Avatar
Default Re: whistling noise in engine when accelerating (slowman)
My 9 month old CRV makes a whistling noise when it is doing 2500 RPM. It only makes this noise at 2500 RPM any gear but not at any other RPM. Is this normal? It has only 3500 miles on the clock.
I haven't modified my car at all except for putting in a dog guard.
Old 01-20-2005, 03:53 AM
mrspeaker's Avatar
Old *** thread
Old 01-20-2005, 04:20 AM
crxfisher's Avatar
Default Re: whistling noise in engine when accelerating (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Old *** thread</TD></TR></TABLE>
And that's a good thing. It means someone actually used the search.
snmont01
Honda Civic (2001 - 2005)
06-28-2011 06:58 PM
stevenwest13
07-17-2005 08:56 AM
YAMAHAtrueracer
Audio / Security / Video
28
01-31-2005 03:23 PM
RCautoworks
01-16-2004 12:26 PM
kommon_sense
16
01-24-2003 02:56 PM
Quick Reply: whistling noise in engine when accelerating
