Where to mount the anchor bolts for my 5 point harness? - Honda-Tech
Old 07-31-2006, 04:42 PM   #1
8atman's Avatar
Default Where to mount the anchor bolts for my 5 point harness?
I havent seen much info on this and my harness i got doesn't really go into detail about where i should mount it anyone have pics for recommendations?
thanks
8atman is offline   Reply With Quote
Old 07-31-2006, 04:49 PM   #2
Crx Jimmy's Avatar
Default Re: Where to mount the anchor bolts for my 5 point harness? (8atman)
it mounts to your roll bar or harness bar
Crx Jimmy is offline   Reply With Quote
Old 07-31-2006, 06:26 PM   #3
Be very careful where you mount it. If the shoulder straps are mounted at the wrong angle you can break your back in a wreck. I suck at explaing things but I think you are supossed to mount it as straight back from the top of the seat as possible. And no more than a 45 degree angle poointing down. Check the NHRA and see what the specs are.
Good luck.
Speed--Freak is offline   Reply With Quote
Old 07-31-2006, 08:59 PM   #4
Tippyman's Avatar
Spinal compression is not fun.
Tippyman is offline   Reply With Quote
Old 08-02-2006, 08:41 PM   #5
8atman's Avatar
Default Re: (Tippyman)
anyone got pics of there mounting setups?
thanks
mouting point for race harness? gosu08 Acura Integra Type-R 6 03-09-2010 03:06 PM
4 point harness where to mount w/o roll bar/cage Gant Honda CRX / EF Civic (1988 - 1991) 34 07-20-2006 10:32 AM
Seat belt harness Mouting Points jdwhat Honda CRX / EF Civic (1988 - 1991) 2 04-29-2005 06:58 AM
Sparco 3-point harness mount points Nothing.Special Honda Civic / Del Sol (1992 - 2000) 4 10-10-2003 04:36 AM
mounting 4 point harness... DOHCarp Honda CRX / EF Civic (1988 - 1991) 16 10-15-2002 07:35 PM
Tags
anchor, bolts, harness, mount, nhra, point, properly, shoulder, straps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
