Where to buy clutch safety switch?
Would really prefer an oem honda one, but can't seem to find it. Anyone have a part number? Or can someone find one that will directly fit like oem? I have an '89 Si by the way.
Ferio Wdm Edition
Re: Where to buy clutch safety switch?
Not the case. One is the clutch switch, and the other is the cruise control switch. They are backwards. Clutch switch button needs to pushed in to connect the circuit, while cruise control switch button disconnects the circuit. Ending cruise control.
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
actually on these some of them had a start relay that required the clutch switch to be pushed in order for the relay to energize, some of them had two separate switches also, OP I will see which one I have
OP find out if the one on your car is normally open or normally closed when the clutch is pushed, and I'll see if the one I have is the same, I know the threads etc will be identical, probably the same connector too
Bubezzy
12-03-2017 03:14 PM
