what's the torque specs for main bearing caps?? - Honda-Tech
Old 05-11-2007, 09:24 PM   #1
ef8sleepr's Avatar
Default what's the torque specs for main bearing caps??
1991 honda civic si sohc zc/d16a6... need the torque specs for the main bearing cap..
ef8sleepr is offline   Reply With Quote
Old 05-11-2007, 09:46 PM   #2
fridaytech's Avatar
Default Re: what's the torque specs for main bearing caps?? (ef8sleepr)
10x1.25 main bolt torque spec is 55nm / 6.5 kg-m / 47 ft-lb
make sure to put oil on bolt threads and washers
also after torquing each cap rotate engine ofter to check for binding
hope that helps
fridaytech is offline   Reply With Quote
Old 05-11-2007, 10:09 PM   #3
ef8sleepr's Avatar
Default Re: what's the torque specs for main bearing caps?? (fridaytech)
i have the same specs on my chilton book but it keeps binding... not sure what's wrong...
Old 05-12-2007, 09:11 AM   #4
fridaytech's Avatar
Different sizes of main bearings may be present in the same engine. To find the correct bearing size for each journal, use the provided chart to properly reference the code markings on block and crankshaft
Old 05-12-2007, 09:13 AM   #5
fridaytech's Avatar
basically there are about four different size main bearings.... you have to figure out which journal needs which size. kind of a pain in the *** but thats how these engines are
Old 05-12-2007, 03:02 PM   #6
ef8sleepr's Avatar
but doesn't main bearings comes in a set???
Old 05-13-2007, 09:52 AM   #7
fridaytech's Avatar
yes they come in a set usually standard size but you can order individual bearings buy color chart. your repair manual may have the main bearing color chart in it..
Old 05-13-2007, 01:18 PM   #8
ef8sleepr's Avatar
any good sites that sells individual sets??
Old 05-13-2007, 01:36 PM   #9
Janos Lin's Avatar
Let me put it this way, the "sets" are usually like ACL, or whatever, those are middle of the road sizes, or green according to the factory chart.
You can only get individual bearings from Honda themselves and they cost quite a bit more once you get all 10 halves, but you can be assured of having consistent and known oil clearences.
Janos
Janos Lin is offline   Reply With Quote
Old 05-13-2007, 02:27 PM   #10
ef8sleepr's Avatar
Default Re: what's the torque specs for main bearing caps?? (Janos Lin)
Janos
ic... but if i just want a set from the parts store which size should i get?? i plastigauge the clearance and my results were .003 in. and the specs on the repair manual says .0010-.0014 on 1&5 journals, 2&4 .0010-.0017, and 3 is .0012-.0019... that's way big right?? so i need undersize bearings??? help me out! and the plastigauge came with 2 colors, i used the red... is that the one i should use???
Old 05-13-2007, 06:14 PM   #11
Janos Lin's Avatar
The sets only comes in ONE size, green. If you want some other size, you have to buy honda bearings. Yes you need to tighten them down some or you'll have too much oil coming out.
You should be using green plastigage. The red one is thicker, and has a different scale.
Janos
Old 05-13-2007, 06:37 PM   #12
amthompson's Avatar
http://www.honda-tech.com/zerothread?id=1169414
According to this thread, the main cap is 33 ft/lbs
This is the info i followed and i had no binding and havent had any problems with spun bearings or anything.
amthompson is offline   Reply With Quote
Old 05-13-2007, 11:16 PM   #13
ef8sleepr's Avatar
Default Re: (amthompson)
hey thanks, i'm going to plastigauge it and double check with that amount of torque and i'll give it a try...
EDIT: I tried it and it is between specs with the green plastigauge and no binding:-D
Old 05-13-2007, 11:42 PM   #14
amthompson's Avatar
So 33 ft/lbs worked?
B18c main cap torque specs JDM Lyfestyle Honda Civic / Del Sol (1992 - 2000) 7 07-13-2009 08:12 PM
need main cap torque specs for b16 redflaredcrx90 Honda CRX / EF Civic (1988 - 1991) 1 02-27-2009 11:31 AM
h22 torque specs RACING INTEGRATION Honda Prelude 2 08-29-2005 08:51 AM
h23 main cap torque specs high_revs Honda Prelude 2 04-28-2005 05:21 PM
H22A4 main bearing cap torque specs please ALLMOTORJ Honda Prelude 4 04-30-2004 10:28 AM
Tags
91, bearing, bearings, caps, civic, compared, d16z6, gsr, h22, honda, journal, main, specs, torque, zc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
