Whats the difference between the 88-91 crx hf, and the crx dx??
Old 02-20-2003, 11:45 PM
AVXHATCH's Avatar
Default Whats the difference between the 88-91 crx hf, and the crx dx??
Just curious, because i originally wanted the hf, but i mighta found a good deal for the dx, whats the difference between the two?? Is the dx fuel injected?? would it be bad to buy the dx?? thanks
Old 02-20-2003, 11:56 PM
Vinceg99's Avatar
Default Re: Whats the difference between the 88-91 crx hf, and the crx dx?? (B16A6rex)
Well the HF is MPFI and the DX is DPFI. So if your planning on doing a swap expect some extra wiring to convert it form DPFI to MPFI not very hard but a bit more work. The HF is also lighter than the DX. What are your plans for it?? You could pick up the DX and do a MPFI swap on it right away that will put you to about the same amount of power as the Si. If your not planning a motor swap I would say get the DX if your going to do a swap then go with the HF it will be less work and headaches in the long run.
Old 02-21-2003, 12:01 AM
crex23's Avatar
All CRX's 88 and up are fuel injected. The HF is the slowest, but also the lightest. A good candidate for a race car provided that you swap the engine The HF came from the factory with about 70-75 HP. The DX has about 80-85 HP. The HF lacks alot of accessories like rear wiper, A/C, rear cargo covers, etc. that the DX has. Hope this helps.
Old 04-28-2004, 11:14 AM
urquidezj's Avatar
Default Re: Whats the difference between the 88-91 crx hf, and the crx dx?? (crex23)
so the zc blacktop dohc swap would be a sinch? or what is needed?
Old 04-28-2004, 11:22 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 &raquo;</TD></TR><TR><TD CLASS="quote"> The HF lacks alot of accessories like rear wiper, A/C, rear cargo covers, etc. that the DX has. Hope this helps.</TD></TR></TABLE>
Not true, my dx does not have AC or a rear wiper. But it did come with a complete rear interior. Also, the HF has a blue interior, my DX has black interior. The DX seats are nicer looking than the HF seats too.
Old 04-28-2004, 01:55 PM
Sampsonite987's Avatar
Default Re: Whats the difference between the 88-91 crx hf, and the crx dx?? (EL Vap133)
Depending on how hard it is to find a rex in your neck of the woods, I know it is difficult to find one in decent condition where I live. I would go with the HF, I just recently picked up an HF and the Si swap was extremely simple. But it all depends on what you plan to do with it.
Mechman456
11-11-2006 11:11 AM
HondaHeddie
09-23-2006 09:58 PM
ef9robert
04-04-2006 04:48 PM
5litereater
06-24-2004 06:01 PM
Way2JDM
03-06-2004 11:26 AM
Quick Reply: Whats the difference between the 88-91 crx hf, and the crx dx??
