What would you do? Ripped outer tie rod boot, sloppy steering? - Honda-Tech
Old 09-24-2004, 01:45 PM   #1
Rywire's Avatar
Default What would you do? Ripped outer tie rod boot, sloppy steering?
Well, my drivers side outer tie rod boot is ripped and there is geece everywhere. My steering is also very sloppy. I yank my rack back and fourth and its seems tight. Do you think the sloppyness is my steering is the rack or the outer tie rod? Obviously the iuter tie rod needs replacing, but should I also do the rack? The rack boots are still good if that helps.
What would you do.
Thanks, Ryan
Rywire is offline   Reply With Quote
Old 09-24-2004, 11:59 PM   #2
Rywire's Avatar
Default Re: What would you do? Ripped outer tie rod boot, sloppy steering? (droppedcrxsi)
anyone?
Old 09-25-2004, 10:19 AM   #3
Rywire's Avatar
in short, will a ripped outer tie rod boot cause sloppy steering? I didnt think so, but someone let me know for sure.
Ryan
Old 09-25-2004, 10:20 AM   #4
rioninja's Avatar
Obviously you should replace the tie rod. Check autozone, they are like $35 with a lifetime warranty.
Just jack that side of the car off the ground, and grab the wheel and try moving it. It will be apparant if the tierod has any play.
rioninja is offline   Reply With Quote
Old 09-25-2004, 10:22 AM   #5
EL Vap133's Avatar
Quote:
What would you do.
Thanks, Ryan
I'd honestly be more concerned about the Geece, did the mama Goose abandon them?
Has your steering always been sloppy, or just recent?
EL Vap133 is offline   Reply With Quote
Old 09-25-2004, 03:44 PM   #6
Rywire's Avatar
Default Re: What would you do? Ripped outer tie rod boot, sloppy steering? (EL Vap133)
HAHAHAHA Vap, you would catch something like that!!! lol
Its been sloppy for a while now, and I think the boot just recently riped. There is no play when I shake the wheel, or the rack. I guess its my rack, I will just replace all the parts at once. While im at it, I can throw some polly bushings in too.
Ryan
PS, so a hf rack would be an upgrade? Tighter ratio?
Steering Rack Questions deerman2701 Honda Civic / Del Sol (1992 - 2000) 0 08-29-2013 11:42 PM
Help with Tie rod end 3k1n Suspension & Brakes 1 03-25-2010 04:03 PM
NTB...alignment ripped my rod boots? mxl360 Honda Accord (1990 - 2002) 4 08-22-2007 12:58 PM
Loose steering after reinstalling rack and pinion? slow91crxdx Honda CRX / EF Civic (1988 - 1991) 5 11-22-2006 06:10 PM
sloppy steering...possible causes? .RTErnie Tech / Misc 4 07-10-2006 04:02 PM
Tags
2002, boot, boots, civic, location, outer, ridgeline, ripped, rod, rods, sloppy, tie, ties, warranty, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
