What tps sensors would be compatible with a DOHC ZC tps sensor?
Old 05-14-2005, 08:40 AM
drewboy's Avatar
Default What tps sensors would be compatible with a DOHC ZC tps sensor?
What tps sensors would be compatible with a DOHC ZC tps sensor? I tryed replacing mine with a z6 tps sensor but the gasket was much larger and didnt fix the problem. Please help!
Old 05-14-2005, 08:49 AM
drewboy's Avatar
bumpo in the attic
Old 05-14-2005, 09:28 AM
drewboy's Avatar
really need help with this, ar there any intake manis i can swap on with tb mounted map and tps sensors without having to make any wiring changes?
Old 05-14-2005, 10:44 AM
Installer1's Avatar
Default Re: (drewboy)
ummmm......the tb/tps off of the 86-89 accura integra will work and you should be able to pick it up at the salvage yard for 65-100
Old 05-14-2005, 12:03 PM
ServiceAdvisor's Avatar
Just about any D-series TPS will work fine, just re-adjust when you install. - Darrell
Old 05-14-2005, 06:14 PM
drewboy's Avatar
I did try the z6 tps but was still receving the code and the gasket seemed to run a litle bigger. Although it did plug in no problems. There are suttle differences when looking at the 2 sensors.
Will the tps error ocntinue if your tps sensor is not adjusted correctly? What I mean is will the tps error continue until I have the 0.5 volts at idle and 4.5 volts at wot.
thanks for the responces.
Old 05-14-2005, 06:21 PM
mar778c's Avatar
Check this thread out.
https://honda-tech.com/zerothread?id=965484
Very easy to do. Props to my Texas peeps.
Old 05-14-2005, 07:37 PM
nikitad's Avatar
Default Re: (mar778c)
Z6 TPS will work, and yes it will. Pretty much any 88-00 <accord/prelude/teg/civic> tps except for 88-91 DX/STD will work.
86-87 teg TPS won't - it's different from 88-89.
If the voltage is out of 4.5-0.5 range, the TPS error will be on.
Did you reset your computer after reinstalling / adjusting the TPS?
If not reset, it will keep showing the old codes.
Old 05-14-2005, 08:01 PM
drewboy's Avatar
awesome, thankyou guys so much for your help. I will go ahead and re-instal the z6 tps tommorow and purchase a multimeter to boot.
Wilka
03-20-2013 03:23 PM
BoRiCuA
06-30-2004 06:06 AM
ActiveAero
08-15-2003 07:40 PM
polycrx
04-11-2003 09:08 AM
Quick Reply: What tps sensors would be compatible with a DOHC ZC tps sensor?
