obd0 to obd1 is this the kit that I need to convert all the wiring?
I need to convert my obd0 wiring to obd1... so I was just wondering if this kit I found will do what I need? thanx for any and all help!
http://www.rywire.com/sitob161.shtml
is that everything I need? $190
thanx guys
thanx guys
yes sir. atleast with the dizzy clip over, if you ever go back to obd0 for whatever reason you wont have to rewire. but thats all you need ( besides a 4 wire 02, obd1 fuel injectors, fuel injector clips that are for the obd1 injectors, and a obd1 ecu)
Re: (beyondspecs_jamar)
I have the whole si harness in my car now and I need to convert it all to obd1. so that will convert it all I have the injectors and everything else becuz I'm swapping the b16a2 obd1 into my car that had an si in it... so will this convert it all?
Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (88 Crx Si)
i just converted to obd1 and i used my obdo injectors.. on my 90 si w/b16a
don't worry I have the ecu yeah I'm sure it wouldn't be that big of a dif with the obd0 injectors but I have everything... I have the whole obd1 swap I just need to convert the wiring and get it going
the shift linkage is 90-93 integra right? and will anything else work?
Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (TH33G4MON3)
If you want us at Rywire to convert your Si harness completely for your new engine you can send it to us along with the OBD1 B16 harness and we'll repin your injector run and distributor, plus we'll relocate your fan switch and run the new sensors through your stock harness as if it came from Honda exactly for your B16 in a CRX/civic
Give us a call at the # on the site, i'll clarify anything you have questions on.
Checkout http://www.droppedcrxsi.com for more swap how-to info (b16 & GSR)
~ Peter @ Rywire
~ Peter @ Rywire
Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (NikoZai)
yeah I was gonna give you guys a call tomorrow thanx alot
dont mean to jack thread
is it worth wiring up the obd1 for the d15b or should i just stick with obd0 dohc zc?
Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (88HaveFun)
? I'm not sure... does it matter? go with whats easier for you
Re: (vw eater)
looks good I just need all the wiring conversions tho rywire has what I need I'm pretty sure I'm just going to call them today
Sleepy_Red_hatch
03-04-2006 08:59 AM
