what size injector for gt15
Old 03-25-2011, 01:02 AM
Sancho815's Avatar
Default what size injector for gt15
im gonna put a gt15 on a d16y8 what size injector should i use? running around 10psi
Old 03-25-2011, 07:02 AM
Honda_Mane's Avatar
Default Re: what size injector for gt15
good luck scrappin up info for that turbo set up i have a z6 that im currently in the process of boost, with the same garrett turbo. Ive gathered a few write ups on my laptop, Ill pm them to you when I get off at 5.
Old 03-25-2011, 07:08 AM
dephtone's Avatar
You need to figure out what your power goal is going to be first.
I'd more than likely recommend 450cc injectors from a 90-94 Turbo Eclipse,Talon, Laser, as these should supply enough fuel for your setup.
Old 03-25-2011, 10:40 AM
Sancho815's Avatar
thanks. were using this turbo for quick spool. its been along time since ive messed with a honda. anywhere near 180hp would be awesome.
whole9
06-14-2007 09:22 AM
Brad
06-20-2004 11:46 AM
omahaturbocivic
10-14-2003 07:26 PM
Tbone
03-11-2003 10:09 PM
Quick Reply: what size injector for gt15
