What is my Honda Engine--D15A, D15B...etc? - Honda-Tech
Old 08-06-2006, 08:55 AM   #1
Default What is my Honda Engine--D15A, D15B...etc?
I am looking for rings for my 1990 Civic 1.5... Can anyone tell me what number applys to my engine?. Thanks
lexluther is offline   Reply With Quote
Old 08-06-2006, 09:44 AM   #2
Suck my DX's Avatar
Default Re: What is my Honda Engine--D15A, D15B...etc? (lexluther)
d15b2
Suck my DX is offline   Reply With Quote
Old 08-06-2006, 09:51 AM   #3
Tippyman's Avatar
Or it could be a D15B1 if he has an Std.
Tippyman is offline   Reply With Quote
Old 08-06-2006, 10:07 AM   #4
Standard tranny?....or standard bore?.. I have both. I have good compression rings, with no apparent blowby. But my car smokes and uses oil, so I guess I am re-ringing it.
Old 08-06-2006, 10:10 AM   #5
Suck my DX's Avatar
hes talking about the std. model in comparison to the dx which has the d15b2
Old 08-06-2006, 10:14 AM   #6
So I have the D15B1... Right? Theres nothing special about the engine its bone stock. I am just wanting to repair it.
Old 08-06-2006, 10:52 AM   #7
Suck my DX's Avatar
well is your car a dx or a std?
dx-d15b2
std-d15b1
the easiest way it to just look whats stamped on your block...its a square section with a code machined into it...if u open the hood its on the left side by the transmission...u might miss it at first if the engine is real grimey, but keep loojkin and u will find it
Old 08-06-2006, 10:53 AM   #8
Tippyman's Avatar
Do you have a 4-speed or 5-speed tranny.
4 speed = D15B1
5 speed = D15B2
Old 08-06-2006, 10:59 AM   #9
Contender25
Guest
Posts: n/a
There the same motor, they just use a differen't cam i believe, but anyways just get the 1.5 engine kit if your rebuilding it, it's gonna fit regardless.
Old 08-06-2006, 11:38 AM   #10
It s a 1990 DX, 5-speed. I didnt know there was any difference between these engines. I put a cylinder head off an '88 LX... Is this OK?.. Is runs good despite the smoke. Thanks
Old 08-06-2006, 11:49 AM   #11
JLefevers's Avatar
if u stilll have good compresion u need to cheack the vaulve seals instead of replacing the rings
JLefevers is offline   Reply With Quote
Old 08-06-2006, 11:53 AM   #12
I have around 185 in all the cylinders, they are all within about 4lbs of each other. The car doesnt smoke when you start it, but once it warms up and you rev it, it puff out the blue smoke. driveing down the road, in third gear, winding it out in the upper RPM;s....you can look back in your rear view, smoke! Lower RPM's it smokes to, just not as much.
D15B17 engine using everything from D15b2 engine simonlebon Honda CRX / EF Civic (1988 - 1991) 5 07-17-2012 08:51 PM
d15b mpg b20vtechatch Honda Civic / Del Sol (1992 - 2000) 39 04-12-2012 11:41 PM
What dizzys will fit a 1.5L engine? nicko360 Honda Civic / Del Sol (1992 - 2000) 4 03-03-2007 08:52 PM
del sol engine mountaindewguy Honda Civic / Del Sol (1992 - 2000) 3 03-22-2005 09:38 AM
what engine is a d15y7? DV98CVC Honda Civic / Del Sol (1992 - 2000) 7 08-27-2002 07:55 PM
Tags
90, civic, crx, d15a, d15b, d15b2, difference, diffrenece, engine, engines, honda, hondas, hondatech, motor, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
