what does the map sensor do? - Honda-Tech
Old 08-29-2003, 11:33 PM   #1
JonGP4's Avatar
Default what does the map sensor do?
does it have anything to do with the fuel delivery? cuz i'm still geting gas miliage in the high 20s, so i figure some other sensor just be ******* up
JonGP4 is offline   Reply With Quote
Old 08-29-2003, 11:36 PM   #2
Chiovnidca's Avatar
Default Re: what does the map sensor do? (JonGP4)
The MAP sensor tells the ECU how much presure is in the intake manifold. (Vacuum)
Chiovnidca is offline   Reply With Quote
Old 08-30-2003, 12:07 AM   #3
EG8R's Avatar
Default Re: what does the map sensor do? (Chiovnidca)
It takes a(meaning one) reading of atmospheric pressure when you first turn the key on and it uses that # to determine other settings.... Fuel mixture, blah blah blah....
EG8R is offline   Reply With Quote
Old 08-30-2003, 12:10 AM   #4
JonGP4's Avatar
Default Re: what does the map sensor do? (skelly ed6)
cool thats what i wanted to know, so it is fuel related
thanks
Old 08-30-2003, 12:59 AM   #5
Chiovnidca's Avatar
Quote:
What do you mean about it taking one reading? What other settings does it determine?
Old 08-30-2003, 03:21 AM   #6
EG8R's Avatar
MAP sensor is the #1 most important sensor in the whole car. The entire fuel and timing map depends on a precise reading from the map sensor.
Better? I can't think right now. Its almost 4:30am....
Old 08-30-2003, 07:34 AM   #7
rioninja's Avatar
For bad gas milage, i would check your o2 sensor if its fairly old. An old sluggish o2 can cause a decent decrese in gas milage.
rioninja is offline   Reply With Quote
Old 08-30-2003, 09:35 AM   #8
JonGP4's Avatar
Default Re: what does the map sensor do? (rioninja)
already replaced it with a 4 wire it helpped alittle bit but not enough for me to be satified
Old 09-07-2003, 12:49 PM   #9
Superhatch's Avatar
To back that up....my MAP sensor just died last night, and the result is that my ecu gives me no spark, or fuel. They car is totally dead. Basically if it doesnt get that reading, then it doesnt run.
The voltage reading across the yellow, and red (from memory...dont quote me) wires is supposed to be 5v. If you dont get a reading "across" them, then put them both on one lead, and put the other lead to a ground. If you still dont get a reading, then you have a faulty MAP sensor.
-Jake
Superhatch is offline   Reply With Quote
Old 09-08-2003, 09:33 PM   #10
Superhatch's Avatar
Default Re: what does the map sensor do? (Superhatch)
I lied. The map sensor wont ever shut off your car. Your timing belt shearing off some teeth, and then skipping on the otherhand...will. Back to the drawing board
-Jake
Old 09-08-2003, 09:37 PM   #11
EG8R's Avatar
I unplugged my MAP sensor the other night while my car was running and it shut off....
Whats a good way to put my car into limp mode?
Old 09-08-2003, 10:43 PM   #12
Before you go jumping all over your MAP sensor, when is the last time you did a full tune up? Is your air filter clean? it should be replaced every 12K (along with your pcv) or cleaned if you have a K&N style gauze filter. How bout the fuel filter? It needs replacing every 12k as well. Don't forget the cap, rotor, and correctly gapped spark plugs, I always check the gap on new plugs which are supposedly pre-gapped you never know if they were dropped, squished, etc.... Also don't neglect the O2 sensor it has considerable impact on fuel economy. Do the easy stuff first as it is likely needed, then if you still have problems grab a digital multi meter and a helms and look into the less likely culprits. HTH
-Joel
B17CR-X is offline   Reply With Quote
Old 09-09-2003, 07:59 AM   #13
DJ_SaNdOz's Avatar
Quote:
-Jake
Uuuuum, no. The MAP sensor will kill the car. Mine went out about 1 month ago while driving & the car kept stalling out & it gave me teh MAP code. I could not keep the car running no matter what I tried until I put in another MAP sensor.
DJ_SaNdOz is offline   Reply With Quote
Do I need an ECT sensor? jemo1 Honda Civic / Del Sol (1992 - 2000) 3 06-05-2013 06:55 PM
9 CYP - cylinder sensor Help... TravisCadello Honda Civic / Del Sol (1992 - 2000) 14 02-06-2013 08:40 AM
d16z6 power steering sensor? Bradsxx7 Honda Civic / Del Sol (1992 - 2000) 6 04-12-2009 03:36 PM
B16 Knock sensor Grnade Honda CRX / EF Civic (1988 - 1991) 5 05-02-2005 09:45 PM
What size o2 sensor socket? B18Redline Acura Integra 4 11-12-2004 11:29 PM
Tags
1992, 2000, accord, bad, car, civic, do, element, faulty, h22a, honda, jdm, map, put, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
