What civic models came with PS, PW, PL, AC, PM
I'm looking to hunt down all the options that my hatch didn't come with.
I DON'T CARE IF YOU THINK ITS STUPID, IF SO, DON'T POST.
I have an 89 civic SI, and I want to put in power steering, power locks, power windows, AC, Cruise and I heard there are also power mirrors.
I KNOW THIS IS A LOT OF WORK, BUT I DON'T CARE.
What models, DX, LX, EX, auto or manual, sedan, hatch, coupe came with these features in STOCK form. I do not care if it was an option, I want to make a list for everybody on here so they know what car WILL FOR SURE HAVE WHAT THEY ARE LOOKING FOR. Also do you know what years these models came with these?
Sedan EX power Steering, power windows, power locks, power mirrors, cruise control, ac?
Sedan LX power Steering, power windows, power locks, power mirrors, cruise control ac?
Sedan DX None?
Is my table correct? The only difference between the EX and LX is the d16a6 motor?
Sedan DX None?
Re: What civic models came with PS, PW, PL, AC, PM (Killa-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killa-X »</TD></TR><TR><TD CLASS="quote">
ALL Sedan EX
ALL Sedan lx</TD></TR></TABLE>
ALL Sedan EX
Re: What civic models came with PS, PW, PL, AC, PM (dr_latino999)
Thanks for the confirmation, has anybody swapped the power windows before? Did you make your own wiring, or did you swap over the relays, and whatnot from the other car as well?
I did the power mirror swap on my crx ( came from an LX sedan)
just need the mirrors ( you can take the harness apart in the door) and
the switch...cut the harness about 6-8 inchs from it. Wiring is very simple.
I had to enlarge the screw holes on my car somewhat but since your is a
civic you may not have that issue.
- Doorlocks...use aftermarket accuators and a couple of relays (DEI 451m pack
works great) and a switch. I pulled a BMW switch for mine..but most doorswitches
may work ( 3 contact) use your imagination.
- rear door motors from the sedans work. I moded up one of my doors and
got it to work....but removed it to work on other things. Sold it to another EF guy.
Re: What civic models came with PS, PW, PL, AC, PM (audioroach)
i THINK You have to change the Steering column to put in the Power steering rack. rack isnt that hard of a job though. I did it on my talon, Not to hard. but I dont know if the that Rack Crossmemeber is the same in the CRX and the LX EX civics.
Re: What civic models came with PS, PW, PL, AC, PM (pogiTSI)
Anybody know if you have to change the rack cross member to swap from manual steering to power steering?
I'm a Jackass
Re: (2nxcrx)
i just bought a 1990 civic 4 door LX for 300 bux and it came with PS, PL, PW,Cruise control, and A/C
i think if you go to the junk yard and find an LX 4 door you should be OK.
Good lUck!
Good lUck!
Re: (2nxcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nxcrx »</TD></TR><TR><TD CLASS="quote">I really want to do a cruise control as well. Anybody have any leads on this?</TD></TR></TABLE>
If you go to autozone or whereever and buy the audiovox cruise control kit for 100 bucks, you can install it on a honda even though it says, "NOT FOR HONDAS", as long as you use a dremmel and bore out the throttle cable connection hole on the throttle body butterfly thing a little bit. This was the only thing that made it difficult for me to add this. OTHERWISE.
Or check out this guys directions under tech.
http://home.wideopenwest.com/~tschmidt/
Re: (Killa-X)
My EX has power steering, power locks, power windows, air conditioning, cruise control and power brakes.
All of them still work.
Not really much of a help... just kind of bragging.
myEB99Si
07-26-2012 12:23 PM
Shift2xlr8
15
07-10-2008 03:45 AM
95civiccoupe31
15
06-10-2002 01:38 PM
