water pump slow leak, now ok?
Old 10-30-2007, 02:00 PM
budomove's Avatar
Default water pump slow leak, now ok?
I had my waterpump and timing belt replaced by a reputable mechanic using aftermarket parts from autozone in february. After a few months, it would drip one drop every few seconds out of the weep hole at the very bottom of the water pump. This happened on and off for a month or so, and I topped off the overflow tank a few times. For the past few months there has been no leak, and no sound. The car has also never overheated as far as i know. would you replace?
Likely the seal/gasket that has since sealed itself with sediment
or the bearing?
or something else?
thanks in advance!
Old 10-30-2007, 02:08 PM
loudandlow's Avatar
Default Re: water pump slow leak, now ok? (budomove)
problems don't fix themselves... if it was leaking out the weep hole, you should replace.
Old 10-30-2007, 02:23 PM
CBURKE's Avatar
Yes replace it
Old 10-30-2007, 09:38 PM
DAP91Si's Avatar
I don't have the service manual in front of me but I think it mentioned that it was normal to see some leaking from the weephole.
Old 10-31-2007, 08:15 AM
EFB055
~sp33~'s Avatar
Default Re: water pump slow leak, now ok? (DAP91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAP91Si &raquo;</TD></TR><TR><TD CLASS="quote">I don't have the service manual in front of me but I think it mentioned that it was normal to see some leaking from the weephole.</TD></TR></TABLE>
only if its about to die.
Old 10-31-2007, 08:32 AM
DAP91Si's Avatar
Default Re: water pump slow leak, now ok? (~sp33~)
I just looked it up and it does say small amounts of "weeping" from the bleed hole is normal.
I've had mine weep before but it is usually large enough to cause puddling.
budomove, I would keep and eye on it and if the weeping is excessive then I would replace it.
Old 10-31-2007, 08:35 AM
loudandlow's Avatar
How long has it been since you had it done. At every shop I've worked at they have a 12/12 warranty. 12 months or 12,000 miles. Give them a call and tell them it's leaking like a sive.
Old 10-31-2007, 09:28 AM
budomove's Avatar
Default Re: water pump slow leak, now ok? (loudandlow)
My mechanic does warranty his work for a year, but I stupidly supplied the parts from autozone to save a buck, and he won't warranty it, since it is probably a defective water pump or gasket he said. I probably saved a bout 15 bucks by buying the autozone wp, lesson learned.
Old 10-31-2007, 09:50 AM
CBURKE's Avatar
Well that's what he would have done anyway, maybe Napa but still not factory OEM parts.
Old 11-02-2007, 05:49 PM
1 Fly SI's Avatar
Default Re: (CBURKE)
I replaced the alternator on my girls car a while ago and it caused a leak. I found out that the alternator tensioner bracket bolt wasn't torqued properly. I tightened it and it was fixed.
Old 11-02-2007, 05:55 PM
loudandlow's Avatar
Default Re: (1 Fly SI)
WHAT?!?
Old 11-02-2007, 06:02 PM
1 Fly SI's Avatar
Default Re: (loudandlow)
Trust me I know what I am talking about.
The alternator tensioner bracket bolt was loose where it bolts up to the block/ It also holds on the water pump. I tightened it and it was fixed. It is a 14mmm bolt.
Old 11-02-2007, 06:24 PM
1 Fly SI's Avatar
Like I said I know what I am talking about.
Old 11-02-2007, 07:34 PM
pepper's Avatar
get OEM dude, that will definitely fix your leak.
Old 11-03-2007, 05:34 AM
budomove's Avatar
Default Re: (pepper)
I am waiting on Majestic Honda to send me some OEM parts including water pump, timing belt, tensioner, and tensioner spring. Hopefully there will be a decently mild weekend coming up when I can do this, before the winter.
Thanks Everybody!
justint7121
11-21-2010 09:46 PM
mizzoEG
07-21-2007 06:00 PM
Draggin99Si
06-08-2007 09:28 PM
baonest
12-09-2006 02:08 PM
crxsi8
10
08-30-2005 10:49 PM
Quick Reply: water pump slow leak, now ok?
