Wat to do about oil?
Old 08-17-2008, 06:55 AM
whiteformula98's Avatar
Default Wat to do about oil?
Ok, so anyway my hatch burns a little oil so i put the lucas stop leak in and it say's for every 4 qts of oil add one quart of the stop leak.....so thats what i do but it is showing it to be a little bit past the 2nd dot on the dipstick meaning its overfilled...what should I do?
Old 08-17-2008, 07:21 AM
Measured it, its about 3/4's of an inch over the second dot.... and by the time the stop leak kicks in it will prolly burn some of it up
Old 08-17-2008, 09:06 AM
BILLETGRIP's Avatar
Default Re: (whiteformula98)
that 1 quart to every 4 is just an example. it doesnt mean that you have to put 5 quarts into something that only holds 4. drain a quart out.
Old 08-17-2008, 10:10 AM
it will burn out i believe it has before...bout 200 mles of driving it will drop some when the stop leak kicks in.....even if something does happen i figure o well its only a d15b1 engine and it would give me reason to upgrade
Old 08-17-2008, 10:27 AM
Rainman
SIred91's Avatar
Overfilling the crackcase causes pressure problems that can blow out your rings and cause severe oil blowby/burning. Not to mention forcing oil leaks in the pan gasket....
There is a reason that there are marks on the dipstick.
Old 08-17-2008, 10:56 AM
pxsx's Avatar
Default Re: (SIred91)
hes right, drain some out man.
Old 08-17-2008, 11:49 AM
burnout8488's Avatar
...Lucas products are crap.
Why waste your money?
MumBleZ_94gsR
05-30-2009 03:26 PM
Inextricabledrvr
05-03-2008 09:42 AM
soundFX
01-07-2007 05:53 PM
yuen
11-12-2006 06:43 AM
deepnite
10-09-2002 01:46 PM
Quick Reply: Wat to do about oil?
