vtec still work with d15b7 dizzy?
sup guys. ive been reading up for the past 2 days and cant find a straight answer. im doing a d16y8 head on my 91 si (d16a6) IM reading that a lot of people are using 92-95 civic d15b7 distributor because it lines right up to the y8 head. will vtec still work even though that dizzy is from a non v motor?? ill be switching to obd1 if that helps. also what should I do about the resistor box???
also has anybody ever used a jdm d16b vtec dizzy on a y8 head?
the parts I have now are:
p28 ecu
obd0-obd1 ecu jumper harness
obd0-obd1 dizzy jumper harness
obd1 injectors
obd1 fuel pressure regulator
y8 head gasket
y8 timing belt
head studs
thanks everybody for input.
p28 ecu
obd1 injectors
y8 head gasket
y8 timing belt
head studs
Re: vtec still work with d15b7 dizzy?
your B7 distributor will work just fine on the Y8 head - the distributor doesn't care if it is VTEC or not - on the Z6 head, you have to use the VTEC distributor, only because it is the only one that will bolt on, not because it is VTEC
Keyboard Humorist
The CYP "snail" is flipped 180 between the nonvtec and vtec distributors.
It does matter if you use a vtec or non-vtec distributor.
Code 9.
Ahh crap... I just ordered a d15b7 distributor too.... I read something about flippin that "snail" anybody ever done that? I've never really looked Inside of a distributor before. I've taken the coil packs out of them but that's all :-/
jg31990
09-06-2012 02:56 AM
IDriveHonda
12-23-2003 09:30 PM
y49crxsi
12-07-2003 05:06 PM
