Vacuum hose routing diagram for a 1985 honda CRX
Old 12-12-2005, 02:09 PM
zurander's Avatar
Default In need of a Vacuum hose routing diagram for a 1985 honda CRX
Hey guys as the name says i need a vacuum hose routing diagram for a 1985 honda crx it seems that the one on the hood of the car is missing and i have not been able to find one...... if any of you could help that would be awesome...
Thanks in advanced
Old 12-12-2005, 09:49 PM
98lude-t's Avatar
Default Re: In need of a Vacuum hose routing diagram for a 1985 honda CRX (zurander)
there is only like 2 or 3 hoses that you need. u can take all of em off and just get a vac plug kit to plug the 3 big vac lines off the manifold. just make sure that you leave the vac advance hooked up and the charcol can and electrical load sense to distributer also hooked up but other than that oh the on that goes to the "3rd" barrel on the carb need to be hooked up also.
Old 12-14-2005, 08:31 AM
zurander's Avatar
Default Re: In need of a Vacuum hose routing diagram for a 1985 honda CRX (98lude-t)
Its the ones that come of the charcol can that i need to know where they go... to be more specific the purge line off the canister is unpluged and i need to know where to plug it in... if anyone knows that would be great. (where abouts on the carb it plugs into is what i need)
Old 12-14-2005, 08:44 AM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Old 12-14-2005, 10:07 AM
zurander's Avatar
Default Re: In need of a Vacuum hose routing diagram for a 1985 honda CRX (88DXCRX)
Now here is another silly question for you guys where is the purge cutt off solenoid valve located on on the engine/carb.... i have no idea.....
Thanks for all the help its been great in getting the problem solved..
uberEFtuner
09-24-2013 11:47 PM
jdmsuckah
06-16-2010 09:04 PM
my77stang
12-31-2009 08:36 PM
crxb18a1
03-01-2005 12:45 PM
Quick Reply: Vacuum hose routing diagram for a 1985 honda CRX
