turn signals blinking too fast
Old 05-30-2013, 08:01 PM
Tan Trinh's Avatar
Default turn signals blinking too fast
my 89 crx si does a weird thing with its signals, when its hot out it blinks slightly fast but slow enough to be able to tell that it is blinking, however when it gets cold outside the blinkers blink so fast that the signal looks solid, has anyone else encountered this problem or knows the cause?
Old 05-31-2013, 07:09 AM
whit3tatt3dn3rd's Avatar
Default Re: turn signals blinking too fast
i have a 91 that just blinks super fast and from some reason when i turn on the right turn signal all my fronts blink super fast like hazards..
Old 05-31-2013, 07:17 AM
JuggerNaut-CTR's Avatar
^That's because there is a bad connection at the ground or the plug itself
Not uncommon
Old 05-31-2013, 07:44 AM
so just get a new plug and see what happens?
Old 05-31-2013, 08:22 AM
^That's what I did. Both sides blinked fast. Both rear worked, driver front worked, pass front not at all. I left the blinkers on and started messing with the wires around the ground and plugs and the pass side started working again. Messed with the driver and started blinking slow again.
Went to the junk yard and got both corner light plugs with a good length of wire. Wired in the new/used ones, and everything back to normal as it should have been.
Old 05-31-2013, 08:24 AM
AFH-Parts's Avatar
If all bulbs are working, it's typically a problem with a ground wire or the relay.
Old 05-31-2013, 09:20 AM
will have to give this a try when i get off work tonight. thanks guys...
Old 05-31-2013, 10:35 AM
would this work also for the guy who started this... feel like a douchebag for stealing his thread...
Old 06-01-2013, 08:00 PM
Tan Trinh's Avatar
will it?
Old 06-03-2013, 07:00 AM
^^ man i messed with my ground cable and it kinda worked now both signals only blink together for about one blink and then they are normal... i really think mines a whole wiring issue the more i get into the car... try it and see what happens dont know how your gonna make it cold again to kinda test it out..
SpecialRequest
05-09-2018 02:51 PM
joshd_bh
14
02-03-2013 10:13 AM
JDMEK-4
03-30-2010 05:16 PM
bakorexer
05-23-2005 10:55 AM
redman223
01-21-2003 12:40 PM
Quick Reply: turn signals blinking too fast
