Turbocharging my CRX - Honda-Tech
Old 05-23-2005, 02:26 PM   #1
SirThelin's Avatar
Default Turbocharging my CRX
Hey
Ive got a Crx with an D16z5 DOHC
Really itchy for a turbocharger.
Searched at Sportscompactonly.com and found a kit for d16a1.
U think it will work?
SirThelin is offline   Reply With Quote
Old 05-23-2005, 03:06 PM   #2
Mach69's Avatar
Default Re: Turbocharging my CRX (SirThelin)
I have no idea what a D16Z5 is! I am not sure if it exists. However, you mentioned that it is a DOHC engine, and the only D-series DOHC engine was the ZC. Is that a D16z5?
If you are talking about the ZC dohc, then that is a great engine to turbocharge. You can piece together a hmt kit.
http://www.homemadeturbo.com/
Mach69 is offline   Reply With Quote
Old 05-23-2005, 08:39 PM   #3
HiProfile's Avatar
Default Re: Turbocharging my CRX (Mach69)
A kit for a d16a1 will fit any mpfi d16 (has same exhaust manifold, and nearly the same t-body placement). Eigher you have a ZC DOHC or a SOHC D16z6, either way it will work. The only reason it wouldn't work 100% is bacase the a1 is from an 86-87 teg, and I'm sure teh charge piping would be different. Regardless, the a1 swaps right into a crx, so I'm sure you'll be fine.
HiProfile is offline   Reply With Quote
Old 05-23-2005, 10:11 PM   #4
Mach69's Avatar
Default Re: Turbocharging my CRX (HiProfile)
Quote:
It swaps in, yes. But not right in. It is a really pain to get the A1 into the crx body, or so I have read. Its not the 'drop-in' like a z6 or ZC engine is.
As far as exhaust manifold and throttle body placement, those are probably the same.
Old 05-23-2005, 10:18 PM   #5
the a1 actually drops right into the 84-87 crx's. the 88-91 a little fab is needed
markdman is offline   Reply With Quote
Old 05-23-2005, 10:20 PM   #6
oh yeah, if your not sure it will work, buy a d16a1 exhaust gasket and see if it will fit on your z5
Old 05-28-2005, 09:09 AM   #7
SirThelin's Avatar
I didnt know that my D16z5 existed before i checked my papers and doublechecked on th block.....It really exist.
So I can bolt on the turbo that fit on the a1 and zc then?
Old 05-28-2005, 04:45 PM   #8
juice91si's Avatar
you have a z5, it was only available in europe, thats why you confused the ppl above. like already mentioned too, everything should bolt up fine. its a d-series so the ex mani will work fine, it is very similar to the jdm zc.
juice91si is offline   Reply With Quote
d16y8 meangreen82 Tech / Misc 3 06-17-2014 02:58 PM
The recommendation for Turbocharger and BOV dcream Forced Induction 17 03-09-2013 09:00 AM
t Hot Sauce 23 Forced Induction 2 01-26-2007 04:43 AM
anyone ever turbocharged a...... 1point5CRX Honda CRX / EF Civic (1988 - 1991) 2 01-09-2004 04:55 AM
whats is better supercharger or turbocharger? sbplay22 Forced Induction 54 04-30-2002 07:29 PM
Tags
charging, crx, d16z5, hmt, honda, turbo, turbocharing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
