turb b16a?
turb b16a?
if i were to turbo my b16a in my 2nd gen crx...what kind of turbo kit would be safest? what would i have to have to run the turbo safely without worrying about blowing my motor?? anyone kno about force feeding b16's??
New User
Re: turb b16a? (JDMB16ACRX)
I've been asking myself the same question. Here is some info that I've gotten from a reputable friend. He owns a 1991 MR2 NA which has now been turbo'd. He's putting out about 300HP. So I think he knows what he's talking about.
Here is what he has told me.
A 1st gen B16 has compresion at around 10.5:1 so it's prety high. What you will want to do is either lower the compression by adding a thicker head gasket or putting in lower compresion pistons or you can keep the stock compression with a low boosted turbo say at around 7psi. I'm going to be doing this next winter and I hope it works fine. I'm hoping for about 225 HP to the wheels. Even if I get 200HP to the wheels I'll be pretty happy. Now for your Turbo... If you want it to spool faster... go with something small. If you want crazy power go with something bigger. You see if you go with a small turbo it will spool up quick but at aroubd 12psi all you will get is hot air which will rob you of power. With a big turbo you will get a slow response but once you do it will be able to wail to some high psi's.
I hope this gives you a bit of help.
Re: turb b16a? (Don)
hmm...the information is helpful...but i'm still worried about blowing my engine...does anyone know what i could do to run the turbo somewhat safely? beside low boost...i know that one already. thanx!
you can run up to 8 psi on your b16 safely w/ a kit like the Drag gen III. you would be making around 250 to the wheels...this kit is very safe, Myself along with many others on this board have been running this kit for over two years w/ out a single problem. you can do a search in the FI forum...you will read countless answers like the one I just gave you
Re: turb b16a? (DragIIcivic)
Don't even worry about blowing your motor the only way your going to blow it is if you get boost happy you can build the block but that's probably what your not talking about your probably thinking what can i ad on to make the turbo safer mostly nothing just don't gun your car out of every turn and you'll stay safe
Re: turb b16a? (XtraFastCRX)
hm...so my b16a should be able to handle say...a greddy kit? i heard of someone that blew there 99 Si motor w/ a greddy kit...dunno the reason....
why dont you go to the forced induction forum? theres alot of info inthere
actually theres a guy in there that has a b16 turbo on his crx...hes from australia. ithink...but hes got a link to his site check it out..
New User
Re: turb b16a? (pagong)
THE B16 MOTOR IS VERY STRONG I HAVE SEEN STOCK BLOCK B16'S WITH TURBO KITS BOOST 15PSI AND RUN 11.7 ON SLICKS IN 4TH GEN CIVIC'S AND CRX'S. JUST DON'T GO BOOST HAPPY RUN 6-7PSI ON THE STREET AND 10PSI AT THE TRACK WITH A LITTLE RACE GAS AND YOU WILL BE FINE
HTTP:\\WWW.TEAM-EVOLUTION.NET
Re: turb b16a? (EVOCELICA)
what kind of turbo kits were they running though? If i were to run a Greddy turbo kit....how much boost can i get out of the kit to be safe? Also what kind of fuel mods would i need if any at all? (what you guys think about the greddy kit...?)
New User
My friend John is running a t3/t4 and everything else is different odds and ends like greddy b.o.v. turbonetics wastegate ect... custom made kits
evo: can you send me a picture of your friends setup. i dont know if i should go cut and weld pipes, mandrel bend w/silicone hose and clamp it. kinda tight in the engine bay with that b16 in there.
New User
well i think that 6-8 psi is very possible. and you cr is at 10:2 not 10:5. greddy si made 220 at 5psi thats pretty good for me. there is also a groupbuy for the revhard stage 2 for 2900.
New User
Re: turb b16a? (b16aLX)
1st time out Leevon Eisele ran 92 Hatchback with RevHard turbo on b16a - 10.49!!!!Note that Myles ran a 9.92 in a turbo b16a that was NOT stroked last year......Mugs can make some power!
ccfab
01-28-2006 11:38 AM
