crx dash in hatch.need info on a plug.
behind the center console where the radio goes there is a little yellow plug with i think 4 wire,just wondering what it was for?TIA Brian
Re: crx dash in hatch.need info on a plug. (d16efhatch)
its not a plug for the lighter cause it has 4 plugs the lighter is only 2.and it dont reach to the clock...
Did it Come off the heater control or maybe the ac switch.. Thats about all it could be besides the previously stated
if you are swapping the crx dash into the civic, there should be no wiring involved. that plug should remain in the crx and should be nothing you have to worry about. i don't remember seeing that plug when i swapped a crx dash into my civic.
Re: crx dash in hatch.need info on a plug. (hatchblack)
hmm could be a old ac plug since i removed the a/c....ill be ripping the dsh out to the to the bottom of it... thanks
ok probably the a/c plug since i removed it,i'll be rippin the dash out to get to the bottom of this...
I swaped a 91 CRX Si dash into my car and the wiring was slightly different form my 90 Std hatch. The only 4 wire yellow plug I saw was above the fuse box but I cut off the wiring I wasnt using IE the radio and heat/ac. The one thing that was different was the clear/white plug for the fuse box. On the CRX harness it was wider and had an extra wire. I was gonna use the civic dash harness but it was hacked to **** and wasnt working so I pinned out that connector and used the CRX harness and now everything is fine . You can always swap the wiring if that makes it eiser.
Sean
Sean
Re: (Concept Tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Concept Tuning »</TD></TR><TR><TD CLASS="quote">I'm confused why your worrying about wiring if your just doing a dash swap.</TD></TR></TABLE> im not worried about it and the dash swap has been done for almost a yr now,i was just wondering what it was for and after further inspection it was for my a/c button with i removed and replaced with a block off plate.........thats alll thanks for everything everyone.
motoxx644
06-09-2008 12:27 PM
