????Torque specs for pressure plate to flywheel bolts????
Old 03-09-2006, 10:34 PM
slowrider's Avatar
Default ????Torque specs for pressure plate AND flywheel bolts????
Car: 90 civic wagon.
Motor: with a stock d15b7 (dpfi)
i need to reinstall the flywheel and pressure plate.
i need to know the torque spec for the flywheel? and the pressure plate?
Note: i did a search and i only found torque spec on the flywheel. is this ture?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02WRX &raquo;</TD></TR><TR><TD CLASS="quote">87 ft/lb on D series trannies with 6 flywheel mounting bolts
Eric</TD></TR></TABLE>
Old 03-10-2006, 11:43 AM
EFworship's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (slowrider)
yeah I think that sounds right. It's been a while since I replaced the one on my '88 LX.
Old 03-10-2006, 01:11 PM
jlicrx's Avatar
87 lb-ft for flywheel
19 lb-ft for pressure plate
Old 03-10-2006, 04:29 PM
slowrider's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">87 lb-ft for flywheel
19 lb-ft for pressure plate</TD></TR></TABLE>
Thanks
Old 03-10-2006, 04:59 PM
jacoop86's Avatar
^correct
Old 03-10-2006, 06:02 PM
ACTman's Avatar
For performance applications we recommend 30 ftlbs on NEW M10.9 grade bolts. I don't trust tightening old bolts that far, but new ones won't twist off until at least 36 ftlbs. Flywheel bolts can go more than stock recommended torque too. If you are just building a stock motor there is no need though.
Old 03-10-2006, 10:12 PM
Cuda70's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (ACTman)
For those bolts, I always use German torque specs..
Guten tite.
Old 03-11-2006, 07:21 AM
HondaFerris's Avatar
19 lb-ft for pressure plate</TD></TR></TABLE> and some blue loctite
Old 03-11-2006, 08:21 AM
Andrew Marquis's Avatar
also make sure you tighten them in a star pattern.. like you would lug-nuts on your wheels.
Old 04-06-2007, 10:53 AM
steveo135's Avatar
Default Re: (Andrew Marquis)
and make sure u lube it all up because with out it the bolts wont be torqued properly
Old 09-21-2007, 07:00 PM
Bob_760's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (HondaFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFerris &raquo;</TD></TR><TR><TD CLASS="quote"> and some blue loctite </TD></TR></TABLE>
I've been using those torque specs and red loctite, no issues yet (and I had to take it all apart after a few thousand miles) allthough I use an impact to take it apart.
what kind of pattern do you use for 9 bolts?
t0p_sh0tta
06-09-2014 10:35 AM
TeinEM2
08-04-2011 07:38 AM
snzh22
06-13-2008 01:06 AM
gsr18cx
09-07-2004 01:04 PM
b18bVtecRS
08-24-2004 03:42 PM
Quick Reply: ????Torque specs for pressure plate to flywheel bolts????
