Torque Spec for rocker assembly D16A6.
Re: Torque Spec for rocker assembly D16A6. (Broken Gearbox)
Oil up the camshaft, wipe the contact points and bolt holes clean.
Get the bolts hand-tight, then torque to 16# each.
Go in this order:
Cyl 3 (middle, front, back)
Cyl 2 (middle, front, back)
Cyl 4 (middle, front, back)
Cyl 1 (middle, front, back)
Then the seal holders on the ends are going to be 9# if you need to do them too.
Do a valve lash adjustment, drive it, then do another once its cooled off.
Modified by fireant at 9:45 AM 9/9/2008
Go in this order:
Re: Torque Spec for rocker assembly D16A6. (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">Oil up the camshaft, wipe the contact points and bolt holes clean.
Go in this order:
Modified by fireant at 9:45 AM 9/9/2008</TD></TR></TABLE>
Wow . Thanks x2
Go in this order:
Wow . Thanks x2
