timing marks on crank pulley... - Honda-Tech
Old 08-02-2011, 06:49 PM   #1
Icon6 timing marks on crank pulley...
hey i know when timing a D15B2 your supposed to use the different color marks on the crank pulley, well what if your pulley is so old there are no more colors? from what i can see there are 3 clustered together and 1 by itself? I bought a EF hatch for $500 needed timing belt, did the timing belt and runs good but i want to double check to make sure I'm at 18 degrees which is what the label says under the hood. thanks for your help!
jimmak85 is offline   Reply With Quote
Old 08-02-2011, 06:52 PM   #2
Gunmetal_B20_Hatch's Avatar
Default Re: timing marks on crank pulley...
base timing should be 16.5 degrees...
The single mark is 0, the middle one of the 3 close marks is your 16.5.
Be sure you jump the service connector when you are checking timing also.
Gunmetal_B20_Hatch is offline   Reply With Quote
Old 08-02-2011, 07:03 PM   #3
that means its timed right cause i put a dot where the middle line is and the mark on the lower cover lines up there, and of coarse i jumped the blue connector next to the ECU. My sticker under my hood says base timing at 18+2 advance I don't know why its different then what you said.
Correct Method for Timing Belt Tension yosuthnmasa Honda Civic / Del Sol (1992 - 2000) 8 04-08-2008 08:29 AM
LS: When setting the timing... JokerTypeR Acura Integra 5 01-21-2007 09:10 AM
Is LS Crank Pulley same as GSR Crank Pulley? integmester Tech / Misc 9 08-28-2004 06:25 PM
d15b7 engine timing 93coupeDX Honda Civic / Del Sol (1992 - 2000) 3 05-04-2004 01:45 PM
Setting the timing without removing the pulley boostedcvc Tech / Misc 3 12-22-2003 11:24 AM
Tags
18, 1992, 2000, accord, civic, crank, crankshaft, ef, honda, integra, mark, marks, pulley, s2000, timing, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
