timing belt installation
Old 11-26-2007, 11:39 PM
  #26
Contender25
Guest
Posts: n/a
About the t-belt, what trys to happen is when you try to align the belt up to everythign it trys to slip on the bottom when your not looking, just double check everything and really make sure it's on timing.
Old 11-27-2007, 03:51 PM
  #27
defnu's Avatar
Default Re: timing belt installation (24TEN)
yeah, timing order is good. getting spark, and fuel.
Old 11-27-2007, 05:01 PM
  #28
PHANTOM MENACE
24TEN's Avatar
Default Re: timing belt installation (defnu)
You originally said you rebuilt your head, have you done a compression test on each cylinder?
Old 11-27-2007, 06:01 PM
  #29
defnu's Avatar
yeah. i didn't rebuild the head fully but replaced all the seals and cleaned the exhaust valves.
Old 11-27-2007, 10:55 PM
  #30
PHANTOM MENACE
24TEN's Avatar
Try doing a compression test. If you have spark and fuel going into the combustion chamber, the only thing I can think of is that you don't have compression.
There's a chance you flooded the engine but I doubt it...unless you were pumping the gas while trying to start it.
Old 11-28-2007, 09:47 PM
  #31
defnu's Avatar
and if the compression is good? actually, my main question is, if it ran fine before the head removal, how can compression rate change after installation? while trying to start the car, it back fires once in a while. and now, about the fuel, i'm not able to smell it when i remove my spark plug wires.
Modified by defnu at 11:04 PM 11/28/2007
Old 11-28-2007, 10:07 PM
  #32
defnu's Avatar
according to the finds, what do you suggest i start buying to replace? ie distributor, plug wires, starter, etc.
Old 10-23-2009, 01:28 PM
  #33
wheelgarage's Avatar
I dug for this one.....
This post, by far, is the best for d-series timing belt change!
Old 10-23-2009, 07:49 PM
  #34
JackFlack's Avatar
agreed , better then the manual.
1. With belt on, place socket and ratchet on crank pulley and rotate crank until the mark on the crank pulley that is off to the right of the three marks together lines up with the mark on the timing cover. “UP” on cam gear should be up at top.
2. Remove the little rubber plug in the timing cover for access to the tensioner bolt.
3. Place socket and ratchet on tensioner bolt and loosen it (DO NOT REMOVE).
4. Take hold of belt just below cam gear on side toward firewall and pull up on the belt to get slack on that side.
5. While holding belt up, tighten the tensioner bolt.
6. Make sure crank pulley marks are still lined up.
7. Lift belt off cam gear and rotate cam gear, with box end wrench on cam gear attaching bolt, until the marks at 3 o’clock and 9 o’clock line up with top of head. Hold the cam gear in position with the wrench.
8. Place belt on cam gear with no slack on the side toward the radiator. Make sure marks on crank are still lined up.
9. Loosen the tensioner bolt so that tensioner removes the slack on the side toward firewall.
10. Rotate crank counterclockwise so that cam gear moves a couple of teeth and belt is tight on the side toward radiator.
11. Tighten the tensioner bolt.
12. Put plug back in cover.
EFjalopy
01-08-2010 02:54 PM
Swansen
15
04-01-2009 02:39 PM
thebleek
10-01-2008 02:39 PM
lv6l
11-30-2005 12:09 PM
agent marlon
11-19-2002 08:32 PM
Quick Reply: timing belt installation
