timing for 1990 integra ls
Re: timing for 1990 integra ls (integda9)
are u talking about ignition timing? 16-18* is good , set it to middle of the three marks on the crank pulley when its idling around 750-800
Re: timing for 1990 integra ls (97grnrs)
its a b18 i got the distrubtor set all the way back twards the back of the car and im only off by like 2 teeth its non-tubro
off what by two teeth? the timing belt timing is something completely diff. u need to set that right before u can adjust the distributor ignition timing .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integda9 »</TD></TR><TR><TD CLASS="quote">well where can i find the timing belt specs so i kno where to set everything?</TD></TR></TABLE>
Line up the bottom end to cyl 1 TDC and then line up both marks on the cam gear that say up, up. Attach timing belt, tighten tensioner. Turn it over a few times by hand and double check that everything lines up.
There are no real 'specs'. You simply line things up.
NatedoggAZ
14
04-13-2005 09:51 AM
