is there any way to clean a catalytic converter? need to pass tomorrow - Honda-Tech
Old 12-20-2006, 07:53 PM   #1
HondaHeddie's Avatar
Default is there any way to clean a catalytic converter? need to pass tomorrow
I know about the guaranteed to pass stuff, but don't have time to run 2 tanks through my car
I need to pass tomorrow
I will replace it asap, but need to pass smog now so I can keep working to earn the bucks for it
I have read of the cat cleaner fluids
or will alcohol work if my cat is getting old(what would max ratio of gas to alcohol be?)
which it is I am sure,
I believe it is the orig, that would make it 250Kmi old
HondaHeddie is offline   Reply With Quote
Old 12-21-2006, 08:07 AM   #2
Default Re: is there any way to clean a catalytic converter? need to pass tomorrow (HondaHeddie)
off to try alcohol
will seafoam revive a sick cat?
puuuuuuuuuurrrrrrrrrrr
Old 12-21-2006, 08:36 AM   #3
thesmogman's Avatar
Sorry to say but there is on reviving method for cats. If you need to pass spend the $100 bucks on a stock replacement cat.
The best thing to do for a cat is to run it for ten or twenty minutes at 3-4000 rpm.
That will burn off any contaminates but that is it as far as I know.
When you get the smog check and you fail you can go to the DMV for an 30 day extension. You need the failed smog check report (VIR)
thesmogman is offline   Reply With Quote
Old 12-21-2006, 09:17 AM   #4
Default Re: is there any way to clean a catalytic converter? need to pass tomorrow (thesmogman)
thank you man
I have about 40% mix denat alcohol in the tank now
if that dont work I will need to figure out how to get the cat
I cant get the ext, I have a ticket for driving w/ exp tag now
I have till dec 30, but need to have it reg'd today for work reasons
emissions test delaware Dohc eg coupe Forced Induction 9 10-22-2012 10:08 AM
Help! Cant pass DE Emissions sniffer Bseriescivic5 Forced Induction 11 07-30-2010 02:29 PM
Adding alcohol to fuel tank to pass emissions? huntarrr Honda Civic / Del Sol (1992 - 2000) 7 11-30-2006 09:20 PM
Denatured alcohol question RCautoworks.com Drag Racing 12 12-15-2004 03:03 PM
How I passed RI emissions with a JDM b16a2!!! No cheating!!! deckster333 Honda Civic / Del Sol (1992 - 2000) 6 09-30-2004 07:16 PM
Tags
2002, alcohol, california, car, cat, catalic, catalitic, catalytic, check, clean, converter, conveter, failed, guaranteed, honda, pass, ramon, revive, san, smog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
