TB whistling
Old 06-28-2004, 07:10 PM
popngen's Avatar
Default TB whistling
has anyone seen (errr.. i mean heard) this before?
story goes:
Removed intake, loosened throttle cable a tad, turned on engine, played with TB with the plate open and closed. Turned engine off, and put everything back tight... no leaks from intake anywhere.
Turn engine back on, and now I have a whistling noise. I double checked everything but couldn't figure out why it started suddenly.
It's definitely coming from the throttle plate, opened maybe about maybe a quarter of the way.
Any clues anyone?
Old 06-28-2004, 09:04 PM
Brrraaaap!
Blaze45's Avatar
Default Re: TB whistling (popngen)
When you hold the throttle a certian way you can hear the air being sucked in and it makes a whislting noise. Nothing to worry about.
Blaze
Old 06-28-2004, 09:33 PM
mr. carpenter's Avatar
Default Re: TB whistling (Blaze45)
did your idle adjust screw come out?
Old 06-28-2004, 10:09 PM
crx si 2004's Avatar
clean it, it will stop, if it doesnt, clean your filter
Old 06-28-2004, 11:23 PM
91civicEX's Avatar
Default Re: (crx si 2004)
try unplugging ur eacv. mine used to whistle too. just went away though never fixed it.
crusto2k3
12-05-2008 08:50 AM
Azxster
07-03-2008 07:36 PM
kevin7kevin7
07-11-2006 12:22 PM
civicaleg
03-27-2005 03:47 PM
SiKSiR
03-16-2002 10:16 PM
Quick Reply: TB whistling
