Symptoms of a bad main relay? - Honda-Tech
Old 03-09-2006, 08:48 PM   #1
O16581724 5 2 5's Avatar
Default Symptoms of a bad main relay?
O16581724 5 2 5 is offline   Reply With Quote
Old 03-09-2006, 09:34 PM   #2
deadon's Avatar
Default Re: Symptoms of a bad main relay? (O16581724 5 2 5)
car does'nt start....you also have to listen really good and see if your fuel pump kicks right before you crank the motor. I think also if you turn on your car, see if your fuel guage goes up as well. I went through a few of them. Also watch you igniter and coil in your distributor. There famous for failure. You can solve the coil with just buying a cap and external coil. As for igniters good luck.
deadon is offline   Reply With Quote
Old 03-09-2006, 09:42 PM   #3
Default Re: Symptoms of a bad main relay? (deadon)
Not a bad main then, i don't know, check my other thread near this one, i'm getting despirate for a solution, i'm stumped. =\
I've read a few threads on bad mains and they're all like you describe, thought maybe there'd be a few freak cases like mine.
Old 03-09-2006, 11:08 PM   #4
JG90CRX-Si's Avatar
When mine was going out it would start the car then turn it off. I would have to wait a few seconds and try again and it would work fine. When it really started getting bad I would have to try cranking it over couple of times and would hesitate to stay on. Finally one day it bit the bullet but it only cost about $42.00 from Orielly/Autozone brand new and fix the problem.
Good luck
JG
JG90CRX-Si is offline   Reply With Quote
Old 03-09-2006, 11:32 PM   #5
Default Re: Symptoms of a bad main relay? (JG90CRX-Si)
Well, the problem fixed itself!
I don't know what i did, but i hooked a battery charger to it, still dead, then suddenly i got all power, tried to start it, everything shut down. Unhooked the battery terminals while it was still being held on charge, got power back, reattached it to the battery, full power back, started right up, let it run for awhile, shut it down, started right back up again, did that about 10 times.
WTB: 5 lug itr 5lug conversion eg_21 Mid-West (Sales) 3 07-15-2013 08:17 AM
Custom 5.5 gallon fuel cell JDM JEFFREY Southern California (Sales) 39 12-14-2011 03:49 PM
5.5 fuel cell JDM JEFFREY For Sale 38 12-14-2011 03:02 PM
CODE 5 willsEK-HF Honda CRX / EF Civic (1988 - 1991) 6 02-21-2006 09:01 PM
Are VX Wheels 13x5 or 13x5.5? Catch 22 Road Racing / Autocross & Time Attack 9 02-06-2003 01:12 PM
Tags
a4, accord, audi, bad, diagnose, distributor, failure, honda, hondatech, integra, main, power, problem, relay, signs, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
