Strange IACV/EACV problem
i recently did the obd1 conversion to my D15/z6 mini me. when i completed it my car idled at 1500 every time i let it idle after driving. if i let it idle for about a minute it would gradually drop to 1000 or jump between 1000 and 1200. oil change seemed to make it a little better. also the strange part is that there is a whistling/humming noise from my intake. when i unplugged the EACV/IACV the whistling goes away and the idle corrects itself but the ecu throws a code. there are no codes when everything is plugged in. anyone have any similar problems?
1 Post
Re: Strange IACV/EACV problem (91civicLX)
Reset you're ECU, and adjust the throttle screw to lower the rpms. But that whisling noise could be a leak, perhaps the IACV gasket isn't sealing properly... Definitely check to see if it's leaking first.
Re: Strange IACV/EACV problem (MrTodd)
could be ill pick up some carb cleaner today and check it out. this problem started when i did the obd1 conversion and didnt change when i replaced the iacv so i dont think its a leak. are there any wiring problems that would make the iacv hum or whistle like that. its pretty audible. i can still hear it 20 feet away witht he hood up. ill try adjusting the idle and restsetin the ecu also. the strange thing is it idles at a perfect 700 when i unplug the IACv
Mario245
53
08-07-2009 07:49 AM
crxfreak1117
09-08-2007 07:05 PM
