sohc zc (non vtec) vs. d16a6 difference
Old 07-07-2006, 07:09 PM
CrxHf-Rider's Avatar
Default sohc zc (non vtec) vs. d16a6 difference
I've searched around and looked. Found rumors and some completely stupid remarks about the difference between the two. The only thing that I am willing to believe is that the zc cam/camshaft has a higher lift than the d16a6. Is this true?
The power difference is supposedly d16a6:108hp and zc sohc:120hp but is there really a difference or is it just some bs?
Old 07-07-2006, 07:15 PM
JOE BD-0's Avatar
Default Re: sohc zc (non vtec) vs. d16a6 difference (CrxHf-Rider)
I've always thought that the zc's valves were like 1mm bigger.....Maybe that's why you can't use that head in NASA?? Where's prkiller? He would know about the NASA part...
Anyone know the real truth?
Got_soy's Avatar
the cam is more agressive,it is the same damn engine otherwise , not a better flowing head, not a bump in compression, just a different cam. oh and it is rated at 120. btw i like mine, its kinda fun
Old 07-07-2006, 07:18 PM
payneth's Avatar
Default Re: sohc zc (Got_soy)
yeah just a high lift cam i thought..
Old 07-07-2006, 07:24 PM
davens's Avatar
120PS = 118HP
I was just wondering because I bought a zc cam and camshaft and it said that it was better than the si. I read into it and it said that the exhaust part has a higher lift giving an extra 10 ponies. So if it works I'll be happy. I only paid like 50 bucks for it.
Old 07-07-2006, 07:27 PM
Also since I would be installing it into my si engine; which I am putting into my hf as a replacement, is it very complicated to do i.e. do I have to make any adjustments or does it just go right in?
Old 07-07-2006, 07:34 PM
Got_soy's Avatar
Default Re: sohc zc (CrxHf-Rider)
just make sure it at everything (cam and crank) is at tdc when you star up or you might get in trouble
Old 07-07-2006, 09:06 PM
bagpipe goatee's Avatar
engine at tdc, you have to torque it down right, and then adjust your valves. there's online manuals telling you how to do it.
oh, also, my sohc zc came out of a '92 integra, no real difference other than the headgasket from a d16z6 (slight advantage) and a "cool" valve cover we didn't get in america.
Old 07-07-2006, 09:08 PM
nappyroots827's Avatar
Default Re: (bagpipe goatee)
well that just about sucks, i have a zc block with a dx head.......GAY!
Old 07-08-2006, 06:48 AM
Where can I get the online manual from?
Old 07-08-2006, 08:22 AM
Rainman
SIred91's Avatar
Default Re: (CrxHf-Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxHf-Rider &raquo;</TD></TR><TR><TD CLASS="quote">Where can I get the online manual from?</TD></TR></TABLE>
ONLINE!
And I would probably bet you that you did not search. Lazyass.
This has been covered many times. Everytime one of the noobies gets an acount.
I searched it and came up with all kinds of info.
Try Again
Old 07-08-2006, 11:12 AM
Vantage's Avatar
What is the comp ratio of a d16a6? i read somewhere the d16a6 was 9.1:1 and the sohc zc was 9.2:1, just want to clear this up for myself as maybe the searching i did was wrong.
Old 07-08-2006, 11:26 AM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">the cam is more agressive,it is the same damn engine otherwise , not a better flowing head, not a bump in compression, just a different cam. oh and it is rated at 120. btw i like mine, its kinda fun</TD></TR></TABLE>the cam has never been proven to be better. an accurate measuring tool was never used when comparing...
Mistabone is in the process of doing an accurate measurement right now. we should have difinitive proof here in a little bit
other than the questionable cam, the motor is IDENTICAL to an a6
Old 07-08-2006, 12:02 PM
haggar's Avatar
Default Re: (SIred91)
Look in the FAQ, one of the first sets of links has dozens of manuals online..
Old 07-08-2006, 12:53 PM
davens's Avatar
Default Re: sohc zc (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">the cam has never been proven to be better. an accurate measuring tool was never used when comparing...</TD></TR></TABLE>
I don't recall you being there...
Old 07-08-2006, 04:54 PM
ryan89crx's Avatar
Default Re: sohc zc (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">I don't recall you being there...</TD></TR></TABLE>care to prove me wrong?
show your testing procedure and the tools used, along with the final results and ill gladly retract my statement
Old 07-08-2006, 05:50 PM
davens's Avatar
You have no idea what was done, you make a dumbass statement like that...and you think I have something to prove?
Keep your retraction. I'm not going to waste my time.
Old 07-08-2006, 06:14 PM
Rainman
SIred91's Avatar
blah blah blah...........a6 has 108hp 100tq
zc has 118hp 108tq.
theres your difference. and yes its the cam. every ******* nut and bolt and part is the same in both engines, swap away.
Old 07-08-2006, 06:53 PM
Got_soy's Avatar
Default Re: (B18a_CRX)
now why would honda make new cast for one enige so i could have a .1 bump in compression, they dont comp is the same
Old 07-08-2006, 06:55 PM
Got_soy's Avatar
dude its been checked a couple time, the exhaust lobe has a higher lift, so off the nuts ok
Old 07-08-2006, 08:11 PM
Vantage's Avatar
holy *** man, u think pretty highly of urself. I said i didnt know about the comp ration. Relax jesus, this is why H-T has such a bad rap.
Old 07-08-2006, 08:24 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">You have no idea what was done, you make a dumbass statement like that...and you think I have something to prove?
Keep your retraction. I'm not going to waste my time.</TD></TR></TABLE>something to prove? WTF are you talking about? until the lobes are PROVEN to be different its just heresay.
i based my statement on what i have read online from other sources. is it right? who knows. you saying that its wrong is the same damn thing. there are differing opinions, and no proof so far either way, yet everyone is supposed to believe you because "you say so"
ya ******* right...
like i said, prove that the ZC cam is better. without any accurate measurements its like i said before, heresay...
and im not on anyone's "nuts", i just want difinitive proof that the cam is better. plain and simple. ok, he measured it. but without explaining his measuring method and results it doesnt mean ****. thats like saying your car is more powerful than somone elses because it feels stronger based on your butt dyno and not having real dyno sheets...
Old 07-08-2006, 08:27 PM
dude, the motors are identical, so where else would the power come from, there isn't a v-tec wizard in the head saying, "i command more power, venne vetti v-techi" the only other place is the cam
Old 07-08-2006, 08:28 PM
ryan89crx's Avatar
Default Re: sohc zc (nappyroots827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">dude, the motors are identical, so where else would the power come from, there isn't a v-tec wizard in the head saying, "i command more power, venne vetti v-techi" the only other place is the cam</TD></TR></TABLE>process of elimination doesnt mean anything either, that still doesnt show how the cam is better, and what lift/duration differences there are
Quick Reply: sohc zc (non vtec) vs. d16a6 difference
