sohc si head on zc sohc block
Pirate General...YARRRR
Re: sohc si head on zc sohc block (hondacrxsiguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxsiguy »</TD></TR><TR><TD CLASS="quote">d1616 head</TD></TR></TABLE> Same head, different cam, the zcs cam is mildly more agressive.
So really you would lose 1-2 HP putting a a6 head on a sohc zc block.
a6 and the sohc zc non vtec are pretty much same freaking motor.
ok....here's my situation, i had a crx si with some head work done to it, it through a rod through the block... i bought another crx si, but it has a zc block with what i think is a d15b2 head. i was wonderin if the zc sohc with a d16a6 head will put out the same displacment
Modified by hondacrxsiguy at 10:18 PM 12/16/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxsiguy »</TD></TR><TR><TD CLASS="quote">ok....here's my situation, i had a crx si with some head work done to it, it through a rod through the block... i bought another crx si, but it has a zc block with what i think is a d15b2 head. i was wonderin if the zc sohc with a d16a6 head will put out the same displacment
Modified by hondacrxsiguy at 10:18 PM 12/16/2007</TD></TR></TABLE> hi remember when i said this?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper »</TD></TR><TR><TD CLASS="quote">a6 and the sohc zc non vtec are pretty much same freaking motor.</TD></TR></TABLE>
Yes you can toss the worked a6 head on a sohc zc block
Re: sohc si head on zc sohc block (***$nyper)
my bad man, j/w did the sohc zc engine come from an older integra or sumthin, ive never heard of a SOHC zc, only a DOHC zc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxsiguy »</TD></TR><TR><TD CLASS="quote">ok, if no one will answer that ?, then the SI wiring harness will work as well?</TD></TR></TABLE>
Yeah. ,the Si harness will on the SOHC zc as well as the DOHC zc. As mentioned before, the SOHC zc head slightly different from the A6 head. The zc cams are hotter, giving you a higher compression, if im not mistaken, aside from that, no difference. Enjoy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxsiguy »</TD></TR><TR><TD CLASS="quote">my bad man, j/w did the sohc zc engine come from an older integra or sumthin, ive never heard of a SOHC zc, only a DOHC zc</TD></TR></TABLE>
The old integra motor was a d16a1 which is like the dohc zc. there are alot of sohc zc motors. Alot of the sohc motors in japan are zc.
Re: sohc si head on zc sohc block (1 Fly SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Fly SI »</TD></TR><TR><TD CLASS="quote">
The old integra motor was a d16a1 which is like the dohc zc. there are alot of sohc zc motors. Alot of the sohc motors in japan are zc.</TD></TR></TABLE>
RIGHT YOU ARE THERE GUY!!!
duefuss
01-24-2008 09:12 PM
cbrodac0424
10
12-10-2007 01:59 PM
