Sohc non vtec zc w/ dpfi
Old 09-26-2012, 03:13 PM
maiden424's Avatar
Default Sohc non vtec zc w/ dpfi
I am going to buy a zc sohc non vtec engine for my 90 civic std.. I want to use my dpfi manifold until I get more fund for a mpfi swap.. Can I do this? What ecu do I use and can I use my distributor off my d15b1 engine? Thank u in advance.. I need some help.
Old 09-26-2012, 03:16 PM
PHANTOM MENACE
24TEN's Avatar
Default Re: Sohc non vtec zc w/ dpfi
Replace your engine with the ZC and reuse the manifolds and distributor. It'll be a one for one swap.
Old 09-26-2012, 04:14 PM
maiden424's Avatar
Use my existing ecu?
Old 09-26-2012, 09:01 PM
PHANTOM MENACE
24TEN's Avatar
Yes.
Old 09-26-2012, 09:42 PM
maiden424's Avatar
Thanks.. I've been ripping my damn hair out behind this thing.
Old 10-01-2012, 09:01 AM
maiden424's Avatar
Ok so another question.. The zc was made to be mpfi. Is my dizzy gonna work? Is it gonna run? I'm concerned about the crank sensors & such or does it not matter as long as I'm running the dpfi im& throttle body? Is it plug & play?
Old 10-01-2012, 09:44 AM
PHANTOM MENACE
24TEN's Avatar
It'll be fine, general rule of thumb is match the distributor to the ECU.
Old 10-01-2012, 11:18 AM
maiden424's Avatar
Ok then.. I'm getting my motor tomorrow from engine world in emeryville ca.. Gonna do the timing belt & seals & such.. We'll see how it go's.. Thanks for the help.. I'll most likely hav more questions later as this is my first honda swap.
crx2010
13
10-16-2015 10:26 AM
Slobuild
01-07-2013 06:14 PM
dmunoz
08-27-2010 07:21 AM
osmbr
33
01-15-2010 05:10 PM
dohc-crx
03-05-2006 02:41 AM
Quick Reply: Sohc non vtec zc w/ dpfi
