smallest wheels on 11" rotor (wilwood kit)
Re: smallest wheels on 11" rotor (audiimportech)
with my Wilwood kit I used 17" BBS RC's , they were great, but my stock 15" wheel would not work. I would guess a 16 would work and maybe a 15 with some crazy offset, but not likely.
Hope that helped
Hope that helped
Re: smallest wheels on 11" rotor (UltimX)
Im sure alot of 15" wheels will fit. Search in the roadrace/autox section, I know this has been talked about many times over there.
Or contact fastbrakes.
Re: smallest wheels on 11" rotor (88 rex)
15" wheel with a 40 offset will fit. I have a 38 offset and had to run a 2mm spacer. correction sorry i have the 12.2 kit so yours should fit easily
be professional
Re: smallest wheels on 11" rotor (91r-e-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX »</TD></TR><TR><TD CLASS="quote">yeah i think u will need something greater than a 38 offset like 40+ with a 15" rim</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91r-e-xsi »</TD></TR><TR><TD CLASS="quote">15" wheel with a 40 offset will fit. I have a 38 offset and had to run a 2mm spacer.</TD></TR></TABLE>
Huh?
+38mm with a 2mm spacer is effectively a +36mm offset.
A numerically higher offset means the wheel will be positioned farther inboard in relation to the hub.
Huh?
Re: smallest wheels on 11" rotor (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Huh?
A numerically higher offset means the wheel will be positioned farther inboard in relation to the hub.</TD></TR></TABLE>
My bad wheel off sets arnt really my stong point
Huh?
Location: Roseville really smells like poo, pooo, pooo, CA
This all depends on the 11" kit you're running. If you're running stock calipers there are a ton of wheels that will fit. If you're running the wilwood calipers you're extremely limited. I have found few wheels that fit (without using a ridiculous amount of spacers thus causing fender rubbing issues because you're a 30+ offset).
My street wheels are Volk CE28N's, 15x7, 42+ offset with 5mm spacers (total of 37 offset).
My track wheels are Team Dynamics, 15x7, 40 offset, no spacer.
The team dynamics have a TON of clearance and the volks have quite a bit of clearance too. Some wheels that don't fit are as follows:
-15x7, 38+ Mugen RNR's
-15x6.5, 38+ Rota Grids
-15x7, 40+ Rota Slipstreams
*Please note that all of my comments are in regards to the wilwood calipers. If you're running stock calipers all of the above mentioned wheels fit.
Re: (K20EF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EF8 »</TD></TR><TR><TD CLASS="quote"> it depends more on spoke design than offset, do a search.</TD></TR></TABLE>
Oh yeah...and Amen to this comment (it actually made sense you stupid Canadian).
haha i should have been more specific. I'm wondering if they fit. I started the thread. They have a 45mm offset and I have not purchased the big brake kit yet.
Re: (RockinthEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch »</TD></TR><TR><TD CLASS="quote">I noticed someone said the +38 offset RNR's didn't fit... Does anyone know if +38 MR5's would fit? That's what I currently have.
Id highly doubt any 15inch MR5 would fit, but dont quote me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch »</TD></TR><TR><TD CLASS="quote">**** I really wanted to get that Wilwood kit too...
Can anyone confirm?</TD></TR></TABLE>
Based on the looks of the MR5, I'm going to guess they won't fit. It's my educated guess too as I have tried several wheels over my wilwood calipers. It's all about spoke design and the MR5's are rather flat.
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91r-e-xsi »</TD></TR><TR><TD CLASS="quote">15" wheel with a 40 offset will fit. I have a 38 offset and had to run a 2mm spacer. correction sorry i have the 12.2 kit so yours should fit easily</TD></TR></TABLE>
you didn't need to shave the caliper at all?!
