Sign of bad clutch cable
What痴 a sign of a bad clutch cable?
Here is my symptom on my 91 EF hatch dx. I do not feather/ride on my clutch or pop the clutch. When I知 in traffic and I知 in and out of 1st and 2nd gear after a while I get very difficult to get it into 1st. I can get it into 2nd if I rev match the rpm but it takes A LOT of muscle to get it into 1st. The rest of the gears 3rd, 4th, and 5th are ok. When the car is off and have the clutched engaged, I can shift in all the gears without any problem. I have a two months old clutch, flywheel, and bearing and just changed out the transmission fluid.
Your help is greatly appreaciated.
I tell doctors what to do
Re: Sign of bad clutch cable (lapulapu)
sounds like a clutch cable, it's probably not bad it just needs to be adjusted. does it grind when you try to put it in to reverse?
Re: Sign of bad clutch cable (ILcrxsi1)
Yes, it does grind if I try to get it into reverse. I don稚 recall EVER getting it into reverse without a grind. Do you recommend just swapping out the cable? I did adjust the clutch cable before changing out my clutch and that worked for two weeks. After that it got worst. I took it to a shop and they said it was my clutch. They said that I might have adjusted the cable too much which in turn wore out the clutch. But now i'm back to my original problem. grrrrr!
Re: Sign of bad clutch cable (BlackLudeSi)
currently, i feel pressure about half-way when I depress the clutch pedal. You're saying i should feel pressure .25 inches from the top of the depression of the pedal?
just throwing out ideas.. but synchro?? if thats going out, it makes first hard as hell to get into.. same as reverse.. happened on my bronco 2 (1988)
you have to adjust the cable after you replace the clutch, it sounds like your cable is a little loose and needs to be tightened up
Re: (gsxr1k05)
Reverse isn't hard to get into, just first. I only grind on reverse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lapulapu »</TD></TR><TR><TD CLASS="quote">Do i also need to look into adjusting the clutch switch clearance?</TD></TR></TABLE>no
reverse is the dead giveaway. reverse doesn't have a synchro so if there is movement then it will grind. the only way there would be movement in the shafts in the trans is
1. the car is rolling
2. your clutch isn't disengaging all the way
you need to pick up the slack in the clutch cable
sr20paisa
10-25-2017 05:15 PM
88crxdxfastwhip
08-02-2006 07:47 PM
srv3fender
03-24-2005 07:16 AM
