Shortening clutch pedal push distance when starting ?????
Old 04-13-2008, 12:00 PM
Rob.'s Avatar
Default Shortening clutch pedal push distance when starting ?????
When I start the car, I have to press the clutch pedal all the way down, almost to the floor.
Is there a way to raise or shorten the push distance of the pedal when starting the car ?
My car is a 1990 civic si.
thanks
Old 04-13-2008, 12:21 PM
Hanmin's Avatar
no. not without some hard working modification which im sure its not worth.
Old 04-13-2008, 12:34 PM
Rob.'s Avatar
Default Re: (Hanmin)
heres the switch. do I tighten it or losoen it ?
Modified by Rob. at 1:58 PM 4/13/2008
Old 04-13-2008, 12:36 PM
Turbo Dan's Avatar
you could get rid of it altogether, the 88 and possibly 89 crx's dont need to push in the clutch to start the car.
if you found out how to remove it to make it function like the 88's
and the q about loosen or tighten, only one way to find out, be an innovator.
Modified by Turbo Dan at 1:44 PM 4/13/2008
Nataku
10-19-2007 11:39 AM
Honduh Uhcord
10-14-2007 02:33 PM
90HcDxR
16
04-30-2005 01:38 PM
deviant1
05-07-2003 11:26 AM
TEGPOWER44
12-16-2002 10:11 AM
Quick Reply: Shortening clutch pedal push distance when starting ?????
