(searched) E-brake Light won't shut off
Like the Title says the E-brake light won't shut off
i made sure the e-brake was disengaged and still nothing
any ideas?
any ideas?
Re: (searched) E-brake Light won't shut off (JRZ88DX)
could be a brake hose. my line cracked on me last december and i finally got sick of refilling my brak resovoir so i replaced the line and havent had an issue since. check ur fluid levels and take a look at your wheels to see if there are any wet spots on the inside sidewall where the fluid leaked down. as long as it isnt a hard line, ull be fine. oh, and dont drive it to ard till u get it fixed (if thats the issue of course)
all is well for now and the light is off( it was the fluid)
now begins the search for my leak
the brake light never came on for me when i needed shoes or pads, even when i was down to the metal shims on the back of the pads lol. it might be a good idea while ur checkin ur brake system though
Modified by www.FEOA.net at 6:18 PM 7/16/2008
Re: (www.FEOA.net)
If you dont find a leak at any of the wheels or wheel cylinders/ brake lines... i'd start taking a look at the master cylinder. The fluid may be leaking from the master cylinder into the booster. Just a thought... Good Luck!
type r 01-1063
04-03-2003 11:04 PM
