rywire vtec sub harness
this is the subharness that has the knock, O2, vtec oil pressure, vtec solenoid, and one other plug that I can't think of right now.
Question, what is the blue and orange wire for?
That is for a toggle switch so you can check what code it is throwing mate...that is once checking engine light comes on you turn the toggle on and it will start blinking.
Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">your hands a dirty, and your pants of bannanannannas on'em.
that's actually my dad in the picture.
until you said something, I always thought they were some sort of messed up camouflage. He sport's those PJ's almost every day. Pull's it off quite well.
Back to the topic on hand...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 »</TD></TR><TR><TD CLASS="quote">That is for a toggle switch so you can check what code it is throwing mate...that is once checking engine light comes on you turn the toggle on and it will start blinking.</TD></TR></TABLE>
So instead of checking the red blinks on the ECU for a CEL, you can wire the orange and blue to a light bulb of some sort that will throw CEL codes? Kind of pointless if you ask me To each his own I guess.
Re: (91.crx.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si »</TD></TR><TR><TD CLASS="quote">
So instead of checking the red blinks on the ECU for a CEL, you can wire the orange and blue to a light bulb of some sort that will throw CEL codes? Kind of pointless if you ask me To each his own I guess.</TD></TR></TABLE>well those wires are mainly used for knock and all that cause most people convert to obd-1 which dont have a light on ecu and goes off the dash check engine light....so if your stay obd-0 then dont hook it up and wrap it up....
oh i see the blue and orange for your harness is the jumper switch. just solder or connected a on and off switch to it. this way you can check your engine codes when needed. Your check eng light will flash.
Sexy Cheese Cake
Re: (yz125rider21)
Its actually really nice. I just hook mine up yesterday. Obd1 crx. Works awesome. So much better then the old paper clip trick for the EG's. I flip the swith and boom it went to town. Flip it back off and the check engine just stayed solid like normal. Nice feature. Hook up a toggle switch. You wont regret it.
