Rust repair tips on how to weld 88-91 CRX rear quarter panels/rocker panels
Old 10-22-2005, 07:40 PM
  #126
vtecn8ive's Avatar
Default Re: (nuckingfuts)
haha I didn't even know this thread was back up.
Yeah I've actually been trying to find new rear quarter panels. I really don't want to hit up the dealership but I am thinking that might be the best place.
I will be doing rust repairs on my brother 90 Civic HB before I get to do my car. Oh well more practise.
I actually just purchased a new 89 Civic HB w/ls swap. And it is pretty much RUST FREE. I got a decent deal too. Just need to fix a fender and either fix or replace the doors and I am good to go
(still want to know how to prevent rust from forming. anythign I could add to the inner panel)
-shane
Old 10-22-2005, 11:49 PM
  #127
SomeDude56's Avatar
Default Re: (vtecn8ive)
the one offa ebay? red?
Old 10-29-2005, 12:58 AM
  #128
richmedic's Avatar
bump for teh reet pics
Old 01-26-2006, 08:12 AM
  #129
Powered By Garrett's Avatar
Default Re: (richmedic)
Old 01-26-2006, 09:23 AM
  #130
HondaJack's Avatar
Default Re: (Powered By Garrett)
Good thread here.
Thanks for spending the time to enlighten me.
Old 01-26-2006, 11:30 AM
  #131
vtecn8ive's Avatar
Default Re: (HondaJack)
The CRX will finally get off the farm and get its spots welded in this spring!!! Look for up dates in the near future!!
Old 01-26-2006, 01:43 PM
  #132
godruler's Avatar
i'd say your rocker is not repairable, cosmetically yes it is, you can patch it and mud it up with plastic but it will never be structurally sound again as if that much of the rocker is rusted then the rest of the metal is definately fatigueded. you can get brand new rockers from honda for $84 per side at http://www.hondaautomotivepart...cgry5=
if you plan on racing around in that little rex i would'nt do anything but replace them if you want the job done right. as for the quarters, yeah you could patch them with new metal but honestly thats what a hack would do, anytime you cut open a quarter and weld onto it it'll rust again in 2 years twice as bad this time though. i'd either cut out the rust, prime and seal the metal and get some body bond to glue in your patch piece, its just as strong as welding but won't rust if you prep the metal right, or i'd just skin the quarter. good luck, peace out
Old 01-29-2006, 09:45 AM
  #133
explictness's Avatar
Default Re: (godruler)
are you going to have a write up on this when ur done?
Old 01-29-2006, 10:02 AM
  #134
vtecn8ive's Avatar
Default Re: (explictness)
yes I will from my experience. As stated keep posted for sometime this spring
-Shane
Old 04-19-2006, 11:47 PM
  #135
ThriLlz_'s Avatar
its spring
  #136
ThriLlz_'s Avatar
its spring
Old 04-20-2006, 07:34 AM
  #137
Deviation's Avatar
Spring time!
Good thread. Thanks for the info!
Old 05-03-2006, 07:38 PM
  #138
vtecn8ive's Avatar
Default Re: (Deviation)
haha. yup and I will be bringing it down soon. I actually just got done with a z6 swap in my HB but I need to weld up an exhaust after thats done BAM this car will be down here and back to work on it! Althought I may be getting deployed soon so lots of fun will keep you guys posted
-Shane
Old 12-17-2006, 11:54 AM
  #139
turbocrixhf's Avatar
Default Re: (deftones0817)
best beat is finding a donor car with good parts that you need then cutting them out and welding them on to your car. use a low heat because the sheet metal on the car will warp rather easily. i think honda also has replacement rockerpanels but they are pricey( but well worth it)
Old 07-21-2007, 01:05 PM
  #140
fizzypopdog's Avatar
Default Re: Rust repair tips on how to weld 88-91 CRX rear quarter panels/rocker panels (vtecn8ive)
alright mate, i am a qualified welder in england with the same problem on my just bought crx. for my car body work and underneath, the best steel to use is called "zintec sheet", its bloody pricey and not always stocked everywhere, it bends well, hardly rusts and welds up lovely, but really mate, use anything you want, 1.5mm steel is about the size you want, you can use galv but grind the welding area clean of it, and dont breath it in, or if you are trying to keep some cash in your pocket, just use old car parts, i,e cut up a bonnett and you have enough steel to do all the cars you will ever own. cut a square hole well around the rusted area, cut a new bit the same size, tack something to it so youdont drop it inside, hold it flush to the edge of the hole you are filling and only do tacks around the edge, fillet as much as you can, dont fully weld it there be nothin left of you wing, bush it about and then body fill and prime, rub down and keep on doing that procedure untill it looks asa good as you can get, any help?
Old 07-21-2007, 03:02 PM
  #141
msinsky14's Avatar
wooow dude, thats not true at all. "two years it'll come back worse..."
well not if u do it right. Im very good friends with a restoration shop in my area, and the owner re-do's quarters on hondas all the time, my old prelude had the rust fixed, fully cut out, and it was aweful, eating the whole panel up. he fabbed some enw quarters and went to town. 2 years later looked as good as the day i bought it. and i live in ohio and drove it for two winters.
just dont do it urself and it will last a long time.
Old 07-21-2007, 08:29 PM
  #142
pauld's Avatar
WHAT???? DO NOT for any reason use oxy acetylene to repair any sheet metal on your car!!! Oxy acetylene wil not only totally warp the panel you are trying to fix, it will drastically change the temper of the metal in about a 6-12 inch radius around your weld. Hondas (and almost all modern cars) are built using a high -strength steel sheet metal. Which means that if you overheat the metal, it radically loses strength, and the integrity of the cars structure is compromised... BAD DEAL. Use a mig welder, and work around the repair area in small spot-style welds, cooling after each spot with a rag soaked in water!!!!
Not meaning to rant, but the horrid amount of poor info on this thread makes me shudder...
Old 08-18-2007, 11:31 AM
  #143
vtecn8ive's Avatar
Default Re: (pauld)
haha ok guys sorry to annouce it but this car never made it. I got to busy and with me getting ready to be deployed i pulled the b16 out of the car and sold it seperately.
Car has been sold. I put a d15z1 and tried getting that to work never got it fully functioning which irritated the hell out of me. i think i got a bad motor. but yeah i sold the car like that.
I did however use some of the steps towards my 85 Crx dx that i rewelded some spots and repainted the car.
what Pauld is what i learned from a local body shop. I plan to work in a local body shop when i get back, hopefully. i want to learn the ins and outs of the business and i have talked with the owner of one specific time a few times in reference on how to paint my car.
But yeah there is some good info on this thread and i wish i could have used it towards my car.
Good luck with those of you that are doing what i set out to do!
-Shane
Old 03-17-2008, 05:26 PM
  #144
Jizzo's Avatar
Default Re: (rasta420)
i saw your crx restoration and was wonderin if you would happen to have any tips for me? i have a 93 civic with MAD rust on it.. its on the rear quarters, the rocker panels, and through the bottom door jambs.. its pretty bad but i was thinken about makin it into a project car for fun.. what would you recommend me to do to fully restore it.. i saw some replacement quarters on e-bay but is there anything else i can do for the rocker panels and the inside door jams connecting to the rear quarters? any tips would be helpful.. thanks..
Old 07-03-2008, 04:45 AM
  #145
phoenix_iii's Avatar
Location: Close to West Chester, PA, United States of America
Default Re: (Jizzo)
pics are all down.
Old 07-03-2008, 04:54 AM
  #146
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
Default Re: (Jizzo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzo &raquo;</TD></TR><TR><TD CLASS="quote">i saw your crx restoration and was wonderin if you would happen to have any tips for me? i have a 93 civic with MAD rust on it.. its on the rear quarters, the rocker panels, and through the bottom door jambs.. its pretty bad but i was thinken about makin it into a project car for fun.. what would you recommend me to do to fully restore it.. i saw some replacement quarters on e-bay but is there anything else i can do for the rocker panels and the inside door jams connecting to the rear quarters? any tips would be helpful.. thanks..</TD></TR></TABLE>
1) not the right forum for a 93 civic
2) uhhhh... paint and body forum?
3) this thread is four years old, stop bumping it
Old 07-15-2008, 05:48 AM
  #147
Default Re: (ComeOnKip)
It's in the FAQ it should be up to date/have working pics...
Old 09-30-2012, 03:57 PM
  #148
habanerored06si's Avatar
Yet again another FAQ with lost information/pics
Old 09-30-2012, 10:44 PM
  #149
vtecn8ive's Avatar
Strange, had admin contact me about this a couple of weeks ago.
I told them I don't have the pictures as they were lost when we-todd-did-racing server went down.
Figured it was removed.
LankorDie
03-09-2018 03:12 PM
FrameFixer
08-12-2009 08:21 PM
Spaceballsthelunchbox
05-29-2003 09:29 PM
LegendLS95
10-11-2001 07:28 AM
Quick Reply: Rust repair tips on how to weld 88-91 CRX rear quarter panels/rocker panels
