Question with GSR swap!!!
Old 09-20-2004, 09:10 AM
CRXLST's Avatar
Default Question with GSR swap!!!
Could I use a B16a ecu and just wire in a knock sensor and be alright or should I just do the OBD conversion and use the GSR ecu???
Old 09-20-2004, 09:15 AM
APEX CRX's Avatar
Default Re: Question with GSR swap!!! (CRXLST)
You should really do the OBD-1 conversion. but its been done either way.
Old 09-20-2004, 09:16 AM
CRXLST's Avatar
Default Re: Question with GSR swap!!! (APEX CRX)
The GSR I am gonna get is a 2000 isn t it OBD2??? Can I run OBD2 motor with OBD1 ECU???
Old 09-20-2004, 09:19 AM
APEX CRX's Avatar
oh didn't see that it was a OBD-2 motor. they have OBD-2 to OBD-1 conversion harnesses
Old 09-20-2004, 09:24 AM
CRXLST's Avatar
I guess I would need an OBD0 to OBD2 conversion, plus the ECU
Old 09-20-2004, 09:55 AM
dr_latino999's Avatar
You can't go from OBD-2 --> OBD-0; well you could but it would be a bitch to wire. Best thing to do would be to go from OBD-2 --> OBD-1.
Old 09-20-2004, 10:34 AM
Rywire's Avatar
Default Re: Question with GSR swap!!! (dr_latino999)
Just wire the obd2 engine as a obd1, its easy.
Use your cars harness, and modify it. Check my site for a how to.
Ryan
akoreanyoungsta
07-08-2006 06:22 PM
3s0n3
03-08-2006 09:42 AM
brotech
12-20-2005 08:02 AM
beedoublejay
08-06-2003 01:02 PM
EKHappy
11-13-2002 05:09 PM
Quick Reply: Question with GSR swap!!!
