reverse lights not working
Old 06-06-2010, 03:26 PM
whitecvcb16's Avatar
Default reverse lights not working
i have a 91 std with b16 engine.and i need to know why my reverse lights are not working. i have changed the reverse sensor three times and still nothing.i put new bulbs in too still nothing.any help finding why will be greatful........
Old 06-06-2010, 07:12 PM
FishaCrx's Avatar
Default Re: reverse lights not working
theres a switch on the transmission that two wires run off of maybe its broken or messed up?
Old 06-06-2010, 09:11 PM
hatchet_honda's Avatar
he just said he replaced that
Old 06-06-2010, 09:16 PM
miguey310's Avatar
that's not the sensor
Old 06-06-2010, 09:22 PM
what else controls the reverse lights besides the REVERSE LIGHT SWITCH on the trans? cause my reverse lights dont work on my b16 ef either. i get power to the wires but the lights dont work..2 switches later..
Old 06-06-2010, 09:27 PM
miguey310's Avatar
there's sensor but that guy said the two wires and you said it said that already
Old 06-06-2010, 09:30 PM
wheres the reverse sensor on a 91 ef hatch? i was unaware there was one...yeah i guess the op's switch wiring could be messed up
Old 06-07-2010, 03:24 AM
rustbucketrex's Avatar
If you have have changed the wiring harness from the original, the wiring at the driver's side shock tower plug could be different, it was on mine. Repin at the connector if this is the case.
Old 06-07-2010, 07:21 AM
EFB055
~sp33~'s Avatar
What is this reverse sensor? Sounds like something for an automatic car.
To OP: try checking for continuity, see where you lose it, then go about fixing the break in the circuit. Vague advice yes, but the concept is right.
Old 06-07-2010, 07:54 AM
netfreak's Avatar
Check fuses? My old prelude had an issue with the reverse lights not working and it kept blowing the fuse.
Old 06-07-2010, 08:07 AM
EFB055
~sp33~'s Avatar
Not to get off track here, but that would be caused by a wire earthing out.
Old 06-07-2010, 05:18 PM
swint2007's Avatar
My reverse lights have always worked in my crx until I swapped in the B16. I've never been able to figure out why they haven't worked since the swap.
Old 06-07-2010, 05:25 PM
D16SiHatch's Avatar
it's located on the top of the trans (d-series) or bottom of the trans (b-series), and is the ONLY thing on a manual transmission that has wires coming out of it.
Old 06-08-2010, 04:26 AM
i have done that and i still have no lights
Old 06-08-2010, 04:29 AM
the two wires that control the reverse lights gone across in the harness.do you think that in a std and a ex harness.do you think that are in different spots in the harness at the connecting point on the passanger side
Old 06-08-2010, 05:46 AM
Jockone's Avatar
This is what I found out on my 91 standard hatch,swapped in a dohc ZC with a DX harness (from 88 I think) and lost back-up lights.
Find a good wiring diagram and check the plugs to make sure.
I also found out that if I left my car in reverse I could switch it of and take out the key and the car would still be running.
Old 06-09-2010, 11:19 PM
i knew this already..ppl are talking like theres a reverse switch(on the trans of course) and reverse sensor..like its something different.
hmmm... id sure like to know why my reverse lights didnt work after my b16 swap. my wiring has power...new trans reverse switch..oh well. it wont pass emissions testing so it has no plates and isnt legally drivable anyways
Old 06-09-2010, 11:20 PM
if the ex was an auto the yes the reverse switch would be diff on the harness...diff spot i suppose
Old 06-10-2010, 11:24 AM
schueytenten's Avatar
I know this may sound dumb, but I had this problem. I took my tails out to polish them, and I didn't plug the harness back in at the back up lights. I plugged in the other parts, but left the reverse lights out. Never even knew either until I was getting new tires and the saleperson nearly backed over me.
burnoutboy
08-28-2013 08:31 AM
JDMJUNKIEMONKIE
10-25-2009 02:17 AM
charlee
04-29-2006 02:46 PM
HondaKPX
07-25-2005 10:44 PM
crx1racing
06-01-2005 11:00 PM
Quick Reply: reverse lights not working
