vtec help please
vtec help please
hey guys my crx is throwing a check engine light and my vtec is not working if install a vtec crontroller will that alow the vtec to kick in? or noo since check engine lights on.. my motor is a d16y6 with obd1
Re: vtec help please
fix the problem then your vtec will come back. are you running a cable or electric vss? if cable it probably just came loose. dont try to bypass a problem instead just fix it since you already know what it is
yea it lets me rev out but just the vtec doesnt work because of the check engine light...
the engine lights on because i have a stock 89 hf cable tranny with a 92 si motor which is a digital speedo computer.... is there an adapter?
on another note, does your vtec solenoid even work? to check it attach a wire to the singe wire coming off the solenoid to positive power source (battery), next you should hear a click. the click means its engaging.
just so you know im running an obd1 converted LS/Vtec with a GSR cable transmission, forget what your thinking about it being the transmissions fault you have a CEL.
