Remote starter and Keyless Entry install, advice needed. - Honda-Tech
Old 11-15-2008, 01:12 PM   #1
vtecn8ive's Avatar
Default Remote starter and Keyless Entry install, advice needed.
I just received my Ultra Start G-11-xr remote starter/keyless entry. Its for my winter car so I do not need an alarm on it, just the essentials.
The car is a 90 Civic 4rd Sedan with OEM power locks.
This is my first time installing it and I have about 2/3 of the wires figured out. However, a couple I'm unsure of are as follows:
Diesel Wait to Start input (i'm assuming since its gasoline?)
Tach Detection input (a/c) (is this needed? i have the wire I would use but unsure if need it)
Re-arm output (-) 250mA
Dis-arm output (-) 250mA
Grouwnd While Running Output (-)
I also, received the instuctions for how to install it into my car (kind of or I wouldn't be asking this stuff)
What do I hook these up to:
dome light,
ignition 2,
ignition 3,
neutral safety switch,
reverse light,
key sense,
I have ideas of what I think needs to be done but not 100%. I haven't had time to research this (plan to tonight after work) Just wanted to get this up asap so people could help me out.
Thanks,
Shane
vtecn8ive is offline   Reply With Quote
Old 11-15-2008, 01:20 PM   #2
zrickety's Avatar
Default Re: Remote starter and Keyless Entry install, advice needed. (vtecn8ive)
the system should have a website or sheet that tells you those wires...i used to have one by bulldog security and this may help:
http://www.bulldogsecurity.com...1.htm
search around some more and you should be good
zrickety is offline   Reply With Quote
Old 11-15-2008, 01:52 PM   #3
D16SiHatch's Avatar
Default Re: Remote starter and Keyless Entry install, advice needed. (zrickety)
This should help you figure out what some of those wires are
http://www.directeddealers.com...t.pdf
-the diesel wait to start (don't need obviously, you don't have a diesel and don't need to wait for glow plugs to heat up)
-tach detection input (is needed, otherwise once you remote-start it wont have any idea if the car is running or not)
-the re-arm and dis-arm output (for if you have a factory alarm that you want the aftermarket alarm to now control)
ground while running(i think is just to activate a relay and turn something auxilliary on while its in remote start mode)
D16SiHatch is offline   Reply With Quote
Python 524/Viper 5204 wiring questions, 95 Integra GSR kchungb17a Audio / Security / Video 11 02-03-2013 02:50 PM
2007 Fit M/T Remote start install tleatham Audio / Security / Video 14 06-28-2012 02:49 AM
Viper 5901 / 98 accord coupe Jdmglenn Audio / Security / Video 18 03-19-2012 12:02 PM
python 990 in 94 integra help super jdm yo Audio / Security / Video 4 11-21-2008 09:57 AM
FS Alpine SEC 100S NEW ALARM em96civicex Northeast (Sales) 7 09-20-2008 05:18 AM
Tags
2002, accord, albany, bulldog, car, civic, entry, ga, honda, installation, installing, keyless, remote, security, starters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
