Rear wiper problem.....
Old 03-16-2009, 09:14 AM
4DRmafia's Avatar
Default Rear wiper problem.....
This is very weird and I have no idea why it just won't work anymore. I was doing a fully restored hatch and reinstalled everything back on the car. Everything else works expect the rear wiper, the rear wiper worked before I tore the car down.
I already replace the wiper switch at the column, replaced the wiper motor itself and it's fully plugged in.
Hatch wiring? Maybe, I not sure, my spoiler brake light works.
Is there a relay for the rear wiper? I doubt it but I'll never know. Keep in mind front wiper works just fine and everything else on the car works great too.
Old 03-16-2009, 09:30 AM
izzyef8's Avatar
Default Re: Rear wiper problem.....
wiring most likely check continuity from switch to the motor then check grounds also
Old 03-16-2009, 09:33 AM
4DRmafia's Avatar
The connector in the trunk where it is for the hatch wiring hardness?
Old 03-18-2009, 02:44 PM
eduardoGTR's Avatar
no, the connector it's in the rear left side of the glass .
If you want I guess I can send you the whirring diagram from the service manual.
Old 03-18-2009, 06:26 PM
4DRmafia's Avatar
yes please if you can do that. that will help put alot.
Old 03-18-2009, 06:37 PM
radex7's Avatar
HI, I recently did this mod, you might find it helpful:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rear-wiper-88-std-hatch-2488126/
Check pinouts on a diagram and compare with yours.
I would check for cut wires where harness crosses from the hatch to the body, inside that rubber hose thing. But you should start with continuity and voltage tests anyway.
Let me know if you have specific questions, as I re-did the harness 3 times before I got it right.
And maybe this...
Old 03-18-2009, 07:07 PM
4DRmafia's Avatar
Alright thanks! that is something to do on my list tomorrow. test the motor 1st and see. my car is an si, so it already have a rear wiper and it was working before i tore down the car.
Iloveyourhonda92
01-27-2016 07:50 PM
radex7
25
03-10-2014 01:18 AM
Efjams24
08-02-2012 12:58 AM
nEoMuGen
04-07-2005 08:43 AM
b16acivicsir
02-12-2004 11:54 PM
Quick Reply: Rear wiper problem.....
