Rear disc swap - brake line question
I'm buying my brake lines and was wondering which application do I need?
If everything I'm using is from a 91 CRX Si can I use the 90-93 Integra brake lines or do I have to get the 90-91 CRX Si lines?
The reason I ask is because Flamenco-T has the Integra lines in stock but not the CRX lines.
Re: Rear disc swap - brake line question (SoulSurfer)
Either one will do the trick. These next two steps are critical for a successful rear disc conversion. Get a 10mm flare nut wrench. You'll strip your flare nuts if you don't. Use the existing compensator arms from your crx. An alignmernt shop wont be able to correct the toe in problem youll experience. I made both of these mistakes. PM me if you have anymore ?'s.
Guest
Posts: n/a
Re: Rear disc swap - brake line question (88 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 SiR »</TD></TR><TR><TD CLASS="quote">...You'll strip your flare nuts if you don't. Use the existing compensator arms from your crx....</TD></TR></TABLE>
Re: Rear disc swap - brake line question (ninjaMONKEY)
90-91 CRX SI, 90-93 Integra, and of course the 90-91 hatch SI and possibly the del sols will work bro.
Re: Rear disc swap - brake line question (Blitzed)
Well I know I can use the CRX or Integra brake lines. But can I still use either one if I'm using CRX calipers? Or do I need to match the brake lines, calipers, discs, and trailing arms? Can I mix and match?
You can use any that will work integra/civic/crx ect. They are all compatible just IM me man if you need answers on the swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 SiR »</TD></TR><TR><TD CLASS="quote">Use the existing compensator arms from your crx. An alignmernt shop wont be able to correct the toe in problem youll experience.</TD></TR></TABLE>
Why wouldnt they be able to fix the toe in toe out problem??
Re: Rear disc swap - brake line question (Vinceg99)
Integra compensator arms are longer than the civic/crx by about 1". Look at where the compensators arms mount to the frame. You'll notice they can be moved left or right. This changes toe in on rear tires.
Basically if you use Integra compensator arms, you're never gonna get the rear wheels straight.
They told me to get a kit to correct the problem. Luckily i had the old arms w/me at the alignment shop. BTW it cost more to install the existing comp arms,than the wheel alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoulSurfer »</TD></TR><TR><TD CLASS="quote">But can I still use either one if I'm using CRX calipers</TD></TR></TABLE>
They both use the same caliper if im not mistaken (integra/crx)
Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">good info and nice visual... if you are going for aftermarket brake lines go for Goodbrige SS Brake lines... worked wonders in my car</TD></TR></TABLE>
Yup! I love mine!
Yup! I love mine!
hey what up
the brake lines i used are s.s.braiaded and they were for a 91 crx si got the full kit front and back with hangers for 90 bucks out the door and they are d.o.t. legal
I dont see a problem using the teg lines
is your e-brake cables swapped out? they differ from dum brakes to disk.
also get some dot-4 brake fluid higher boiling point and its not a whole lot more to spend? any waygood luck let me know how it works.
Single Overhead Hamster Cage feed em the good cheese they like it haha.
signing off
signing off
Re: Rear disc swap - brake line question (91' Z-6 Canadian hatch)
Thanks for the replies guys.
I aready ordered the Goodridge brake lines from Stan, I'm ordering the Brembo blanks soon, and am deciding which pads to buy.
92civicfreak
06-02-2008 03:03 AM
HamiltonRex
04-23-2004 04:18 PM
alexdog69
04-15-2004 03:28 PM
chadmasterc
02-24-2004 08:23 PM
