Distributor bearing, where to buy new one??
Old 09-14-2007, 08:28 AM
superex87's Avatar
Default Distributor bearing, where to buy new one??
Hey guys, The bearing in my disrtibutor has alot of play in it and i would like to replace it without spending a ton of money on a new distributor, Theres a thing in the fac describing how to replace the bearing but I can't find a place online that sells the actual bearing. I have searched and how found nothing.
The fac says a company called Nachi makes a bearing that will work, part number 6001NLS but I can't fine it for sale anyware.
so where can I find this bearing???
Old 09-14-2007, 10:04 AM
sauceja's Avatar
Default Re: Distributor bearing, where to buy new one?? (superex87)
Find a distributor king dizzy on ebay. look for username flyingpat
Excellent prices and the best there is. They come complete and ready to bolt on.
Old 09-14-2007, 11:53 AM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Is this for a B16?
The number on the bearing I had is 6001 N-S-L
and I found one through NAPA..
The NAPA part# for the replacement was 6001-2ZJ
and they will probably have to order it for you.
I have rebuilt one and can tell you it can be a pain
to get apart..Do use heat on the tiny screws as they are loctited..
A couple of mine broke anyway...
Old 09-14-2007, 06:33 PM
superex87's Avatar
Default Re: Distributor bearing, where to buy new one?? (88DXCRX)
Yea iv taken apart a disrtibutor befor wasent too bad, I never used heat eather, but thanks for the clarification the the part numbers, also this is for a d16a6 distributor
Old 09-14-2007, 07:28 PM
Tippyman's Avatar
I was unaware that you could replace the bearing.
Old 09-15-2007, 03:32 AM
superex87's Avatar
Default Re: Distributor bearing, where to buy new one?? (Tippyman)
yea you can, finding the new bearing is the difficult part
Old 09-15-2007, 05:11 AM
7PSI CRX's Avatar
Here ya Go!
Old 09-15-2007, 11:51 AM
EFSiR's Avatar
Default Re: Distributor bearing, where to buy new one?? (7PSI CRX)
Do heat the little screws to get them off. Before you even attempt to change the bearings, check the condition of the wire harness that's right at the bottom of the distributor, if they appear as if they're about to fall apart, go with a new replacement.
As for the bearings, the question you want to ask yourself is:
Will this bearing work long in the temperatures it'll be subjected to.
jdmdelsol51
09-17-2014 05:11 PM
Clipsed
02-18-2010 12:13 AM
EnSAn
08-04-2006 12:29 AM
dELfONiK
11-22-2005 08:42 PM
x00gsr
10
12-03-2004 04:55 PM
Quick Reply: Distributor bearing, where to buy new one??
