quick ecu code flash question
Old 03-30-2005, 09:17 AM
Turbo Dan's Avatar
Default quick ecu code flash question
i have the zc pm7 ecu and it flashes 1 fast flash and then pause, then 17 fast flashes.
that can't be 17 right? cause 17 would be a long flash and 7 short ones.
Old 03-30-2005, 09:33 AM
EP3_05's Avatar
Default Re: quick ecu code flash question (Turbo Dan)
Correct. It should be one long flash and then 7 short ones for code 17.
Old 03-30-2005, 11:14 AM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan &raquo;</TD></TR><TR><TD CLASS="quote">i have the zc pm7 ecu and it flashes 1 fast flash and then pause, then 17 fast flashes.
that can't be 17 right? cause 17 would be a long flash and 7 short ones.</TD></TR></TABLE>
Ask yourself this then, what else could it be? Code 17 is no big deal, I've been driving around with code 17 for some time now . And if you have a code 1, thats oxygen. Unless if you are talking about the one fast flash when you turn the key to the on position.
I know on a PM6 ecu it flashes 17 single, short flashes for code 17 (no long flashes), if that helps at all.
Old 03-30-2005, 12:27 PM
black88si's Avatar
Default Re: quick ecu code flash question (Mach69)
does it flash once, then 17, then once then 17 then once? or just once then repeat the 17? Your car is OBD0 therefore it will count out all 17 flashes.
Just plug your Speedo cable back in, it will get rid of this code. It either came out at the tranny side or out of the gauge cluster.
zenon8890
06-25-2009 12:03 PM
type Gendy
12-31-2004 10:46 AM
t0eKnEe
12-17-2003 01:48 AM
IamVtec
12
11-02-2002 04:50 AM
maximedx
05-30-2002 01:41 PM
Quick Reply: quick ecu code flash question
